Switch for MSD to CPR
Old Nov 9, 2014 | 11:07 PM
Steeve_Civic's Avatar
Default Switch for MSD to CPR
Running MSD box and MSD coil and would like to change to CPR on hondata.
Is it worth?
My spark plug gap is .21 at the moment.
My setup is around 750hp (best trap is 158)
Is there any back to back about this switch?
Old Nov 10, 2014 | 02:17 AM
SwappedTURBOegg's Avatar
Default Re: Switch for MSD to CPR
my fwd car trapped 153 on 100% stock ignition(lots of stock ignitions going very fast out there) heavy ek street car on s300. why are you upgrading having problems? kiss if not surprised you got your msd box to even work.
Old Nov 10, 2014 | 02:35 AM
rudebwoy's Avatar
the reason I switched to CPR was because ignition was breaking up above 7000rpm, turned out the problem was not the MSD but a faulty harness, I changed to rywire... but ever since I switched to CPR everything is perfect.
Old Nov 10, 2014 | 05:08 AM
luck4rmkc's Avatar
My CPR has been working great @ 750whp
Old Nov 10, 2014 | 09:25 AM
No problem at all with my MSD box and MSD coil even at 9500rpm.
Just asked If I could keep standard gap (.027) on my plugs in order to get more ignition.
Do you think I need to change If I go over 800hp?
Old Nov 10, 2014 | 03:45 PM
phantom_bcw84's Avatar
i did that exact same swap. went from MSD box and coil to CPR and that was the best mod i have done to date. i was getting ton of spark blow up in high rpms changed to CPR and never had a problem again!
i was able to make my gap bigger when i swapped to CPR
Old Nov 11, 2014 | 01:21 PM
Thank you which MSD coil were you running?
How many rpm had you problems?
Old Nov 11, 2014 | 02:13 PM
i had the HVS II big blue msd coil. and i dont remember what RPMs i was having issues. i just remember i was having lots of issues with spark blow out.
i rev to 9300 RPMs and since i changed haven't had a single problem and it helped soooooo much
Old Nov 11, 2014 | 03:41 PM
kcevo's Avatar
I run s2000 coils on my setup with a .015 gap. NGK BKR9EIX plugs. I rev to 11,000 rpm no problem and see 45+psi of boost down the track and trap 175mph in the 1/4. Still on the same plugs for over 100 dyno pulls and 25 track passes and not one hint of break up. Love the coil on plug and the security of not having a failure of a CDI box possibly (been there at an event). I run MoTeC M800 and a 16v system too.
Old Nov 16, 2014 | 10:55 AM
You should put over .015 gap I think.
Thank you
Old Nov 19, 2014 | 03:43 PM
What is your spark plug gap?
Old Nov 20, 2014 | 01:57 PM
my spark plug gap i think is .24 now. with the MSD stuff it was like .13
Old Nov 24, 2014 | 12:09 PM
Is CPR working fine with S300 v1?
Old Nov 25, 2014 | 04:34 AM
Turbokraft's Avatar
CPR works fine w/V1. I have it on my daily street car now w/over 4000 miles. Starting time is increased by about one second otherwise you don't know it is there.
Old Nov 25, 2014 | 01:49 PM
Thank you, I m going to go with the deal!
Old Nov 28, 2014 | 09:50 AM
Where can I buy the Q37 transistor?
Old Nov 28, 2014 | 12:49 PM
rudebwoy's Avatar
did you mean Q31 ?
Old Nov 28, 2014 | 01:08 PM
Not Q37
Coil Pack Retrofit
Old Nov 28, 2014 | 01:28 PM
rudebwoy's Avatar
Originally Posted by Steeve_Civic
it should come with the CPR.
Old Nov 29, 2014 | 12:22 PM
Yeah you right, just got the answer
Old Aug 8, 2015 | 12:05 PM
Still didn t switch, any idea If it could get me some more hp past 850hp?
Rev at 9800rpm and 33psi of boost without ignition problems
Old Aug 30, 2015 | 11:59 PM
I heard it was more difficult to start up, need a better battery, is it true?
Old Aug 31, 2015 | 01:04 AM
king06's Avatar
At 33 psi I'm pretty sure your going to have spark blow out, IF the igniter doesn't crap out first.
I just picked up my CPR, and it increases crank times by about a second, but at that much power I'm sure you won't be driving it on the street so I don't see why a hard start would even matter. Also, I haven't seen anything about needing a better battery anywhere. I don't see why you would.
Old Sep 8, 2015 | 11:36 AM
Thank you
trav39562
Jan 11, 2009 02:08 PM
ricekiller1
Jul 8, 2006 01:05 PM
GSR4U2NV
May 12, 2006 05:49 AM
Jared
Nov 3, 2002 07:09 PM
