Honda CR-V & Element 2WD & 4WD Element & CR-V
Pins for lambda?
Old Jan 1, 2011 | 11:59 PM
STOMANATA123's Avatar
Default Pins for lambda?
Hi,
Happy new year to all
I want to ask you about pins (on ECU) for lambda sensor?
I have CR-V 1999 year, 2.0i. On some users manual i found that i have 2
lambda sensonsor, but i change my catalytic converter and there isn`t 2nd
lambda sensor on it. I only have lamba with 4 pins (2 for signal and 2 for
heating) before catalytic converter.
But i have LPG system and have problems with "check engine" light, so i want
to use lambda simulator/emulator, but i don`t know where (on ECU) is
connected lambda sensor.
Can somebody help me with this?
Regards
Old Feb 3, 2011 | 02:21 PM
chui816's Avatar
Default Re: Pins for lambda?
sounds really complicated
good luck
Old Feb 3, 2011 | 03:13 PM
Targa250R's Avatar
be professional
He wants to know which pins on the ECU are for the primary oxygen sensor.
Old Feb 3, 2011 | 05:02 PM
Jaker's Avatar
Actually he wants to know the pins for the secondary O2 sensor so he can install the O2 simulator since he has a check engine light from not having the secondary O2 sensor in his exhaust since his cat change.
Old Feb 3, 2011 | 06:23 PM
94EG8's Avatar
Seagull Management
I'm guessing from the way the post is written along with some of the wording that the OP isn't in north america, although I could very well be wrong. Most other countries only had a primary O2 sensor and no secondary. OP, what country are you in?
Old Feb 4, 2011 | 08:44 AM
Ls_dx's Avatar
Just get the secondary o2 plug and trace the wires (colors) back to the ECU
skaternak
Jul 10, 2008 07:46 PM
dre2day
Feb 27, 2008 07:27 PM
prostreetonline
May 23, 2007 09:06 AM
DevilS2000F
Honda S2000
Jul 6, 2002 11:46 AM
gsr stuie
May 1, 2002 10:18 AM
