02 sensor code p0141 seconary sensory light wont go out
i got a code p0141, i replace the 02 sensor front and back and the code is still there? do you think it has to do with a faulty ,ELD,?
be professional
Re: 02 sensor code p0141 seconary sensory light wont go out
Where did you get the sensor? What is the brand and part number? What year, model, and trim level is the vehicle?
part is a , OEXTRA, ROA1196, DOWN STRAM 02 SENSOR, I GOT IT OFF EBAY FOR $46, ITS A OEM PART, THE CAR IS A O3 CRV, LX 2.4 ENGINE
be professional
The OE secondary heated oxygen sensor is likely either an NTK 24410 or a Denso 234-4125, and either one will cost you a lot more than $46. There's a reason for that.
What did you replace the primary sensor with?
the up stream o2 sensor was deneso and i had a code for that but the code went away when i install the part. i orginaly had 3 codes, po141, and p1298ELD,
Pothole987
Honda Civic (2001 - 2005)
08-23-2011 08:22 PM
