Honda CR-V & Element 2WD & 4WD Element & CR-V
installing arp head studs
Old Aug 29, 2012 | 03:15 PM
black0hatch's Avatar
Default installing arp head studs
do you use the lube on the threaded side that goes down into the block? or only on the side with the nut and washer? also the book says torque to 63 but the arp paper say go to 80 so im guessing since there not stock bolts i torque it to 80?
Old Aug 29, 2012 | 07:53 PM
el crapitan's Avatar
Default Re: installing arp head studs
80 yes.
and i like to use a bit on the block threads myself. also the threaded nut side as well. and both sides of the washers
Old Aug 29, 2012 | 08:17 PM
LDForget's Avatar
you dont have to on the block side since it doesnt get torqued, but i always put a little on it anyways. You do have to use it on the nut side though.
Old Aug 30, 2012 | 04:45 AM
thanks. do any of the studs go into water jackets? the paper says if they do i got use sealant. its been a while since i did a head gasket but i dont think they do.
Old Aug 30, 2012 | 01:29 PM
LDForget's Avatar
no i dont believe so.
phelpsj2
Feb 13, 2012 03:26 PM
hYbRid_Eg6
Jan 26, 2012 10:00 PM
LSEGHATCH
Aug 17, 2005 08:45 AM
flip1199
Aug 2, 2005 12:28 PM
kabaroo
10
May 21, 2005 10:41 AM
