Honda CR-V & Element 2WD & 4WD Element & CR-V
weak spark
Old Oct 12, 2012 | 07:49 PM
LDForget's Avatar
Default weak spark
Well, ive run out of idea's. my b20b has pretty damn weak spark. changed ICM, coil pack (new), spark plugs (new V powers), spark plug wires (NGK Blue), still weak spark....Anyone have any idea's? It runs...but really low on power and looks very weak.
Old Oct 12, 2012 | 09:28 PM
www.megameet.org's Avatar
Default Re: weak spark
First off pull out that v crap and put in ngk regular plugs, gapped right, then get oem wires. Finally check and make sure your valve alignment is good, grounds, timing. No engine codes? Do the cap and rotor?
Old Oct 13, 2012 | 04:31 AM
LDForget's Avatar
i had regular ngk plugs in there, no change. both sets are gapped properly. oem wires vs ngk shouldnt make that much of a difference. My original wires were completely fucked and shocked you right through the wire. timing is good. no engine codes. my next guess was to try some booster cables from the battery to the block to check ground. i did the cap and rotor about 6 months ago. what do you mean about valve alignment?
I cant afford to just throw parts at it as i was just laid off yesterday due to low work....
Old Oct 13, 2012 | 03:31 PM
Aligning the gap on the valves in the head. It is supposed to be done like every 30k max. They get tight over tie instead of loose and **** up the head.
Old Oct 13, 2012 | 04:02 PM
LDForget's Avatar
Valve lash adjustment you mean? how would that effect spark? although i agree, i should do it, i just dont see how its related.
Old Oct 13, 2012 | 08:43 PM
What you think is weak spark may be another issue.
Old Oct 13, 2012 | 10:01 PM
LDForget's Avatar
no....its weak spark. i checked the spark before and after changing the wires. it got better, but still weak.
Old Oct 14, 2012 | 06:01 PM
el crapitan's Avatar
use an HEI tester to confirm that it is indeed weak spark. they're cheaper than dirt and you should own one anyways.
if it fails the HEI test, i'd look into just replacing the distributor altogether
Old Oct 14, 2012 | 08:57 PM
LDForget's Avatar
so i stuck an old plug on there and cranked it over....weak spark. bend the ground right up straight, amazing spark.....im thinking i just have to open up the gap a bit on each plug.
Old Oct 14, 2012 | 09:02 PM
did you not gap them before you installed?
and yes, a shorter gap will lower firing kilovolts
Old Oct 15, 2012 | 04:16 AM
LDForget's Avatar
I was 4.5 hours away from home and they were pregapped plugs (-11's, so 1.1mm, which is in the 1-1.1 mm spec for the V). Figured they would be fine. Im gonna pull them all and regap them today.
Old Oct 15, 2012 | 11:11 AM
LDForget's Avatar
opened the gap up to 45 thou, seams to run a lot better.
Notorious_T
Feb 19, 2009 08:33 AM
White94Civic
15
May 9, 2008 05:40 PM
meagainsttheworld
Mar 19, 2007 07:11 AM
nuezdaman44
May 7, 2006 08:00 PM
TeamTooQuick
Apr 17, 2002 04:07 PM
