Merging dump into 4" DP
Old Feb 27, 2014 | 07:39 PM
SPOOLINmatt's Avatar
Default Merging dump into 4" DP
Anyone have any data that would advise against merging my 60mm dump tube in with my 4" going out the hood? Trying to keep it a little simpler and cleaner. Single 60 in a forward face config.
Old Feb 27, 2014 | 09:38 PM
Ron Burgandy's Avatar
Default Re: Merging dump into 4" DP
I've heard that the exhaust flow restricts the dump tube flow as the dump tube is trying to exit with exhaust.
I'm sure there are people with data that will come forward.
Old Feb 27, 2014 | 10:23 PM
nonvtecallmotor's Avatar
Our GN and Prelude are done this way. I see no down sides.
Old Feb 28, 2014 | 02:44 AM
tepid1's Avatar
This is incorrect all around.
The wastegate has priority, being the higher pressure of the two.
There is no issue with doing it this way. I just did this on my car for this year with the new manifold/exhaust setup.
Old Feb 28, 2014 | 05:21 AM
That's good enough for me guys. The 60 hangs right over the exit of the turbo so it just makes sense to merge it in smoothly.
Old Feb 28, 2014 | 06:44 AM
jdm inc's Avatar
Does it matter if u merge before or after wideband sensor
Old Feb 28, 2014 | 06:50 AM
tepid1's Avatar
Why would it matter?
Old Feb 28, 2014 | 06:52 AM
spectacle's Avatar
Shouldn't matter.
Old Feb 28, 2014 | 07:52 AM
Dwh_Performance's Avatar
Me personally I don't see where it would change anything
Old Feb 28, 2014 | 08:56 AM
jdm inc's Avatar
Wasn't sure. Thanks!
Old Feb 28, 2014 | 09:48 AM
Check. Higher pressure dump tube flows to lower pressure exhaust. Makes sense to me.
rorik
May 28, 2008 01:11 PM
turboteg90
Nov 25, 2007 04:43 PM
dezerte
Mar 8, 2007 06:57 AM
boondockgtr
Nov 13, 2003 10:00 AM
SoulSurfer
Oct 20, 2002 02:05 PM
