clearances for high hp e85
Old Feb 26, 2014 | 04:46 AM
Lindomar85's Avatar
Default clearances for high hp e85
good morning fellas..
i would like some input of guys running e85 600-750 whp on ring end gap and bearing clearances..
what clearances do you guys recomend?
i have a 81.5mm jepistons.. p2w is set at 45 thou.. goal is 600+ hp running e85r
thx in advance
Old Feb 26, 2014 | 10:12 AM
CHEETAH's Avatar
Default Re: clearances for high hp e85
i typically run around the same gap and same bearing clearances for all motor...if you're very picky you can run very slightly tighter since the engine will run cooler vs. gasoline...but its a boosted setup so prolly just stick will same tolerances
Old Feb 26, 2014 | 10:29 AM
gringotegra's Avatar
We shoot for 17 on top ring and 19 on the middle.
Old Feb 26, 2014 | 10:32 AM
hondatech8798's Avatar
My block was just done at golden eagle and am using cp's and they set it at .0045 and said good for up to 1000 on e85... I was thinking that was to tight but they would know more than me on that subject
Old Feb 26, 2014 | 10:40 AM
Pro-SeriesFab's Avatar
I would put it close to these numbers.
Depends on how much street driving you plan on doing. I would do .005" per bore for a blown e85 motor and then .002-.003 larger on the 2nd.
Sounds like the .0045" number you got was per 1" of bore size.
ChokeOnMySmoke
Feb 3, 2009 05:59 AM
808b18c1boosted
Apr 21, 2006 08:58 PM
fullblown
Jan 15, 2006 09:39 PM
turbociv
15
Oct 21, 2003 06:46 PM
1.8T_EG
Nov 27, 2002 11:38 AM
