HELP for SWAP
Old Dec 29, 2013 | 11:06 AM
calebmeat's Avatar
Default HELP for SWAP
Hello,
my name is Ivan and im from Bulgaria. I got 95' EG civic hatch with d15b2 engine. I buy a b18c4 and i can't find info for what engine loom i have to look for... So HELP me please
Old Dec 29, 2013 | 11:09 AM
SwappedTURBOegg's Avatar
Default Re: HELP for SWAP
the d15 harness
Old Dec 29, 2013 | 11:20 AM
calebmeat's Avatar
Are you sure??? I was told that I need to get on d16z6??? If this happens by D15 do I have to redo anything on it???
Old Dec 29, 2013 | 11:50 AM
civic-steve-94's Avatar
You can use whatever harness from that era, as long as you add the wiring for VTEC and the knock sensor. Now some single cams have the vertical facing throttle body, you may have to cut and extend some connectors. You also have to wire up the same stuff in the sub harness to the computer. If you have time you can use a couple wires that aren't necessarily important and move them to the slots for whatever you need in the pcm connectors.
Old Dec 29, 2013 | 12:16 PM
calebmeat's Avatar
Thanks guys I'll write if something went wrong.
Old Dec 29, 2013 | 05:42 PM
10sec4door's Avatar
That's pretty cool from Bulgaria
Old Dec 30, 2013 | 12:25 AM
calebmeat's Avatar
Thats not all The b18c4 going to be on boost with 67mm edge
Unphzd
Aug 30, 2010 12:53 AM
myflyintegra
Apr 1, 2010 06:47 AM
phrack3r
Mar 10, 2010 07:27 PM
DCRB
Aug 25, 2008 08:29 PM
hatch b16a guy
Dec 21, 2005 10:20 AM
