Dropping weight
Old Jan 24, 2014 | 09:57 AM
djsimm89's Avatar
Have a eg hatch si model with only a driver seat dash has been cut (prob 3lbs now) no heat ac or ps components at all all windows are lexan except front and back windshields and most of the spare sheet metal inside is gone minus the pillars near the front sunroof has a sheet metal plug from ccc of the car so
It weights 2100 with me in it and I want to get closer to 1800 any recommendations??
Soon to come will be
Fcs fuel cell Lexan front and back windshield Franks custom fiberglass hatch Ks front drag brakes Within 6 months ks rear trailing arm setup
Any advice on hitting this weight goal things I can cut out ext or is there a weigh to get lighter than 1800? I have heard some cars weighing in at 1600 without tube chasis? have pics that I will post later
Old Jan 24, 2014 | 10:01 AM
djsimm89's Avatar
Old Jan 24, 2014 | 10:28 AM
paulzy's Avatar
Default Re: Dropping weight
tailgate
rear glass
lighter brakes
lighter 1 piece seat
lose the gut
fuel cell
gut the hood
Old Jan 24, 2014 | 10:35 AM
djsimm89's Avatar
Originally Posted by paulzy
tailgate rear glass lighter brakes lighter 1 piece seat lose the gut fuel cell gut the hood
Already doing all of that and I only weigh 160 lol
Old Jan 25, 2014 | 11:26 AM
AllMtrRex's Avatar
Either your bathroom scale is off or the scale you are using to weigh the car w/ driver is off.
2100 lbs gutted, with lexan, cut doors and 160 pound driver is way off.
Old Jan 25, 2014 | 12:22 PM
djsimm89's Avatar
Originally Posted by AllMtrRex
Either your bathroom scale is off or the scale you are using to weigh the car w/ driver is off. 2100 lbs gutted, with lexan, cut doors and 160 pound driver is way off.
Cars also a h2b which ads weight compared to a bseries but idk
Old Jan 25, 2014 | 12:55 PM
Nonvtec eg6's Avatar
Mine weights 1760 with me (im 100 pounds) and i have fiberglass hatch/hood lexan all around exept the front gutted only cut doors and a 5 gal cell
Old Jan 25, 2014 | 01:42 PM
Steeve_Civic's Avatar
Lighter wheels, which ones are you running?
Old Jan 25, 2014 | 02:03 PM
SiRCiviC94's Avatar
where to get fiberglass tail gate?
Old Jan 25, 2014 | 02:04 PM
Garage 808 Hatch's Avatar
spare tire well.
Old Jan 25, 2014 | 02:31 PM
djsimm89's Avatar
Steelies in the back lensos on 24.5 in the front
Old Jan 25, 2014 | 04:35 PM
luck4rmkc's Avatar
Skinnies and a kirkey will shed a few lbs
Old Jan 25, 2014 | 09:33 PM
Tex Blackwell's Avatar
Composite doors? Not sure what kind of class care you're building this for. LMK
Old Jan 26, 2014 | 04:40 AM
You can get the rear screen here
http://www.lexan-windows.com/window-...ar-screen.html
Old Jan 26, 2014 | 07:54 AM
DraginX's Avatar
Get an aluminium seat, the recaro's are typically pretty heavy. Probably save 30-50lbs there alone.
Old Jan 26, 2014 | 06:09 PM
allmotorhatch's Avatar
The firewall is 2 layered. Remove the in cabin layer, also there will be a significant amount of sound deadening between firewall layers. Also the undercoating and seam sealer from under the car, including wheel wells really add up.
Old Jan 27, 2014 | 06:11 AM
djsimm89's Avatar
I didn't know that is it spot welded like everything else?
Old Jan 27, 2014 | 07:21 AM
Yes it is spot welded in many places, you will also have to cut in a few areas as well. If you drill out the spot welds, try not to swiss cheese the engine bay from inside the car lol.
Old Jan 27, 2014 | 07:45 AM
djsimm89's Avatar
Yea I'll try lol I'm tryna lose as much weight as possible by cutting before I go buying light parts
Old Jan 28, 2014 | 06:46 AM
FrankFast...'s Avatar
Yeah the scales ur using are off car should at least be at high 19xx the way it sits IMO
Old Jan 28, 2014 | 10:41 AM
djsimm89's Avatar
I think I had a full tank at the time I can't remember
Old Feb 3, 2014 | 09:06 AM
djsimm89's Avatar
Little update from over the weekend
New fiberglass hatch from franks custom fiberglass and rear lexan window
Up next is the front windshield and fuel tank
Old Feb 4, 2014 | 05:15 PM
bauergold's Avatar
Attachment 352809
Nice, this car is going to be light!
Old Feb 4, 2014 | 06:11 PM
HAVideos's Avatar
Attachment 352809
are you happy with that hatch? I've been wanting to buy a coupe trunk from Franks but there were no pictures available. Pretty good quality?
Old Feb 5, 2014 | 05:53 AM
djsimm89's Avatar
Yea I love it!!! It fit perfect no issues at all mounting it was a little confusing for me cause I wanted it to be a certain way but besides that it's grey and extremely light fast shipping and all highly recommend franks
87 SiviK Si
49
Oct 29, 2011 05:10 AM
Xx98civiclxX
Apr 28, 2010 03:41 AM
tommymoose
Jul 29, 2004 11:02 PM
viet4gvtec
Nov 25, 2002 10:11 PM
Mike_C
15
Apr 29, 2002 04:38 AM
