Build needs help
Old Feb 15, 2014 | 10:59 PM
jakescivicsi's Avatar
Icon6 Build needs help
I'm in the middle of ordering parts for my turbo build here's what I have.
70mm turbo
Top mount manifold
44mm tial wastegate
Gsr block
B16 head
Ls crank eagle rods
30x11x3 intercooler
I will sleeve it for 84 mm I want to run 10.6:1 compression my concerns are will eagle rods hold up I have seen a k series on 30 lbs 700 plus hp run them an rev limiter is set at 9500 on that car but I was told to buy turbo tuff rods just need advice
Old Feb 16, 2014 | 01:04 AM
SwappedTURBOegg's Avatar
Default Re: Build needs help
eagle rods are fine.
Old Feb 16, 2014 | 04:43 AM
luck4rmkc's Avatar
If you can afford it you will never be sorry you put TTs in it. I have had good luck with eagles at 600 whp in a previous build though.
Old Feb 16, 2014 | 07:30 AM
Thanks guys
Old Feb 16, 2014 | 10:16 AM
I ordered wisecos 84 mm pistons emailed erl for my block just need cams an it will be on the dyno in May hoping to hit 700 plus
boostedb16EG
Nov 3, 2012 11:16 AM
boostedb16EG
Oct 26, 2012 12:00 PM
jdmpoweredsol419
Jun 2, 2009 05:34 AM
yz125rider21
Mar 27, 2006 08:05 PM
Bulldogg83
Sep 3, 2002 10:27 PM
