what could do this to the valve?
Old Nov 15, 2013 | 07:43 PM
bigG's Avatar
Default what could do this to the valve?
Took apart a head I purchased and trying to find out whats going on here with 2 of the exhaust valves
Old Nov 15, 2013 | 07:44 PM
bigG's Avatar
Default Re: what could do this to the valve?
I was told it was from m1 fuel so I posted here since any1 with experience would be in here
Old Nov 15, 2013 | 10:43 PM
DDTECH's Avatar
Running no filter, is that intake or exh side?
Old Nov 15, 2013 | 10:59 PM
Ron Burgandy's Avatar
Sometimes reading gets tough when ders dem picturizations up.
Looks like possible detonation..... Funky for sure.
Old Nov 16, 2013 | 12:24 AM
bigG's Avatar
Just the exhaust side on 2 valves in diff cylinders
Old Nov 16, 2013 | 12:26 AM
bigG's Avatar
My guess was detonation from to much exhaust heat and the valves were switched around, these are rev xvt valves if that helps any1
Old Nov 16, 2013 | 03:11 AM
Natural Aspirations's Avatar
The pitting from corrosion?
Old Nov 16, 2013 | 04:40 AM
bigG's Avatar
its not all around the valve just where i took the pics
Old Nov 16, 2013 | 05:34 AM
They look as if they were "refurbished" it's a few bucks to replace the effected ones and if that's worth your peace of mind it's worth it.
Old Nov 16, 2013 | 06:04 AM
bigG's Avatar
i will probably replace them all with something better anyway and go oversized on the intakes. i want to replace the guides, its a alaniz head and has oem guides cut down
Old Nov 17, 2013 | 02:16 PM
tepid1's Avatar
Turbo motor? Looks like it was from antilag
Old Nov 18, 2013 | 05:17 AM
bigG's Avatar
all motor i bought it from pelonbuilt on here, the one in the tbmotorworx 350whp thread
Old Nov 18, 2013 | 05:33 AM
xenocron's Avatar
Exhaust valve would be CLOSED when combustion is occurring, detonation occurs AFTER spark plug is lit.
My guess would be foreign object...possibly a spark plug losing a portion of its tip or porcelain during normal running.
Old Nov 18, 2013 | 06:51 AM
SOHFAST94's Avatar
Just a question but what is that? I circled it with RED.
Old Nov 18, 2013 | 07:15 AM
ekcoupeh22's Avatar
is that a crack??
Old Nov 18, 2013 | 07:23 AM
SOHFAST94's Avatar
That's kind of where I was going with it.
Old Nov 18, 2013 | 08:37 AM
bigG's Avatar
just a scratch with the light hitting it at the right angle. anyone know if the new rev valves are the same as the old xvt valves? looking for a price on 2 replacements before i decided to re do the head over.
Old Nov 18, 2013 | 05:14 PM
DDTECH's Avatar
Old Nov 19, 2013 | 06:04 AM
bigG's Avatar
Yea brain fart on my part, I would think damaged wouldn't only be on the back of the valve then in one section if it was something foreign. I think it was heat related though, big stroke 17:1 comp is going to need to get a lot of exhaust gas out and fast. Bouncing off the limiter maybe , either way will probably upgrade to some oversized exhaust inconel valves.
Old Nov 19, 2013 | 07:16 PM
Bizarre's Avatar
My guess would be a corrosive fuel like you were told. I don't see how a foreign object would damage only that part of the valve and none of the combustion chamber.
Old Nov 19, 2013 | 07:19 PM
SPOOLINmatt's Avatar
foreign objects have a tendency to perform magic at 10,000 rpm.
Old Nov 20, 2013 | 05:14 AM
bigG's Avatar
Anybody have any issues at all with rev valves? If I don't need to change the intakes, I will leave them and either ferrea or supertech on the exhaust.
Old Nov 24, 2013 | 04:23 AM
4piston's Avatar
Valves are cheap all things considered. Just replace all of them. Another 140 or so likes on my FB page and I'm giving another set away. We have given about 10 sets this year.
Old Nov 24, 2013 | 04:37 AM
bigG's Avatar
5 angle was already done on the intake side didn't really want to mess with that side except for the guides, andi already liked u guys lol. Awesome work btw.
Old Nov 24, 2013 | 05:02 AM
nonvtecallmotor's Avatar
If you do guides you need another valve job.
