A/F sensor placement in uppipe
Old Jan 9, 2014 | 08:21 AM
cornfed's Avatar
Default A/F sensor placement in uppipe
Wondering where u guys are placing ur a/f sensors in ur uppipes? My buddy just got done with mine and on my second sensor and now second one is not reading correctly. Uppipe forms alot of moisture in it when warming up so not sure if that could be my issue. Any thoughts???
Old Jan 9, 2014 | 09:34 AM
tepid1's Avatar
Default Re: A/F sensor placement in uppipe
I killed a sensor too not too long ago. What I do now on my Motec M800 is set a warmup delay so that the engine is warm and moisture is out of the exhaust before the heater element on the sensor turns on. Haven't killed a sensor since then.
Old Jan 9, 2014 | 03:44 PM
A L I A S's Avatar
i've always turned the sensor on about a minute or so before i turn the engine on. be it cold or warm start, summer or winter. i have about 1400-1500 street/track miles on the setup, and have yet to have a sensor go bad. and as for placement its about 6" from the turbo outlet and about 7 inches from the tip at the hood at a 90* angle (horizontal to the ground )
Old Jan 9, 2014 | 04:41 PM
SPOOLINmatt's Avatar
i always install the sensor after warmup for the days activities.
Old Jan 9, 2014 | 04:48 PM
Turbo-LS's Avatar
I have mine close to top of the pipe slight angle back and8 inch from turbine. Works great I leave in and fire car up. Burned one out when sensor was on bottom of pipe. Ethanol makes a lot of water on start up and that ruined sensor.
Old Jan 12, 2014 | 07:22 AM
cornfed's Avatar
Thanks for the tips from everyone...believe my placement is good just need to wait for warm up to put in or turn it on. Run S300 is that possible to turn on after warm up?
skateboard_ej8
Apr 5, 2011 09:21 AM
TurboEM1
Jun 16, 2005 02:22 PM
