rsx wiring help
Old Dec 23, 2013 | 09:14 AM
kazaa187's Avatar
Default rsx wiring help
Hello im trying to eliminate all the wires possible i can the car isnt gonna have dash or no lights with fuel cell external fuel pump now do i need any wires under dash? Also under the cam sensors on the plastic wiring cover theres about 20 wires go into a plug that just sits ontop of the plastic cover what is that
Old Dec 23, 2013 | 09:49 AM
xenocron's Avatar
Default Re: rsx wiring help
Not sure why this is in the drag section...
The plastic plug on the factory harness is a distribution block, it has both Power and Grounds in it shared by a variety of sensors or relays.
As far as the wiring, you can remove it all, and only add back in the wiring you need. You are going to save a ton of weight and be able to have a much more functional setup for a race car.
Hit up a harness builder or wiring expert like Joel at RaceSpec and they generally help you out much better.
Old Dec 23, 2013 | 10:02 AM
kazaa187's Avatar
Ok thanks i put it in here because i figured some people in drag racing have eliminated most of wiring
adriancws6
Jan 10, 2013 05:39 PM
EGcivicBoy
Feb 2, 2004 01:10 AM
hagrid
Audio / Security / Video
Dec 4, 2002 09:05 PM
rasta420
May 6, 2002 06:58 AM
