Using a intercooler core as a radiator??
Old Feb 10, 2014 | 08:27 AM
1FASTHF's Avatar
Default Using a intercooler core as a radiator??
Looking for input on using an intercooler core as a radiator. Anyone using them on anything other than straight drag cars? I'm aware of the mini radiators that Speedfactory, FCS and DP make but if I'm not mistaken those cars are on ethanol fuels. I'm planning on keeping mine on gasoline and unfortunately I can only find intercooler cores in the dimensions I need. Any input is appreciated. Thanks.
Old Feb 10, 2014 | 09:40 AM
E Town DSM's Avatar
Default Re: Using a intercooler core as a radiator??
pretty sure a company like C&R will make a custom radiator to your specs
Old Feb 10, 2014 | 09:42 AM
redboost10's Avatar
C&r
Spike radiators
Ron Davis
Will all make whatever dimensions you want.
Old Feb 10, 2014 | 05:03 PM
hondatech8798's Avatar
I wonder what cores would work best..
A condense fin design like a Garrett or something less dense and maybe have quicker coolant flow like a cheaper core?
Old Feb 10, 2014 | 05:05 PM
narfdanarf's Avatar
I have a SpeedFactory radiator on my vette. They will make you whatever size you need. I have also used custom sized Dewitts and C&R in the past with good luck.
Old Feb 10, 2014 | 05:08 PM
redboost10's Avatar
What was wrong with the oem unit on the vette? What model is it?
Old Feb 10, 2014 | 09:27 PM
mechanix619's Avatar
OEM doesn't look as sick as the SpeedFactory custom radiators.
And extra bonus if it has -AN fittings.
Old Feb 10, 2014 | 09:48 PM
narfdanarf's Avatar
OEM was in the way of all the other **** that got put in there. Most notably being the billet 80.
Old Feb 10, 2014 | 09:53 PM
redboost10's Avatar
Gtx45?
Old Feb 11, 2014 | 02:30 AM
V-SPEC 1's Avatar
I'm in the same boat, I'm thinking of making a custom radiator using an intercooler core.
Old Feb 11, 2014 | 02:36 AM
SA DUDE's Avatar
Hi.
As far as my sense tells me an intercooler core is a high flow core , if you plan on using your car for longer than the average quartermile run i would stick to a radiator core. on the other hand some guys may argue that the radiator can only let trough as much or as little water as the thermostat allowes.
look into "electronic water pumps " if you wish to take some load off your engine
Old Feb 11, 2014 | 11:35 AM
1FASTHF's Avatar
I'm aware of the company's mentioned and have contacted them but would really like to build the radiator on the car. My margin for error is 0 since I'm using -20 lines and those things don't like to flex. The Fluidyne with Spal fan and shroud that I have works awesome but I want to "tuck" the radiator to free up some room.
Old Feb 11, 2014 | 12:17 PM
redboost10's Avatar
Will -16 not suffice?
Old Feb 11, 2014 | 02:55 PM
1FASTHF's Avatar
I'm already using the -20 hose ends...
Old Feb 12, 2014 | 12:13 PM
Almtrhb's Avatar
See tryna be all fancy and ****. Now look hahhaa
cvcrtonv
Welding / Fabrication
Jan 18, 2014 10:45 AM
Manny1987
Sep 29, 2008 11:46 AM
stealth-wrx
Mar 28, 2006 03:58 PM
theharlequin
Jan 18, 2006 07:48 PM
silver_nteg
Jul 10, 2004 03:24 PM
