PPG final drive cracks.?
Old Mar 12, 2014 | 11:07 AM
BillyEG92's Avatar
Default PPG final drive cracks.?
Has anyone ever have this same problem?
Old Mar 12, 2014 | 12:34 PM
MARC P's Avatar
Default Re: PPG final drive cracks.?
what size tire are you using and clutch?
Old Mar 12, 2014 | 01:52 PM
Blown90hatcH's Avatar
This and how old is that ring gear?
Old Mar 12, 2014 | 02:01 PM
redboost10's Avatar
that's insane. is it literally cracked between every tooth? that is something i have never broke or cracked on a liberty dog box and a gforce dog box, the ring gear. and i know the ppg stuff is exponentially better quality than the two mentioned.
Old Mar 12, 2014 | 02:30 PM
tepid1's Avatar
Excessive tire shake. Seen it before
Old Mar 12, 2014 | 03:08 PM
SPOOLINmatt's Avatar
that is a healthy crack job. My liberty has been through hell....ive cracked the pinion before but never the ring gear.
Old Mar 12, 2014 | 07:58 PM
BillyEG92's Avatar
24.5s
Clutch master twin
Old Mar 12, 2014 | 10:33 PM
GodFather of Boost's Avatar
Never seen this before. Not even stock trannies. The only trans I've ever seen cracks on the ring gear is the gforce. They seem to do it about every 30-40 passes. But those cracks were horizontal. In your pic they are vertical. Just very weird.
What ring gear size is that? Gsr?
What's the counter shaft look like?
Tepid, u have seen these exact cracks before?
Old Mar 12, 2014 | 10:38 PM
BillyEG92's Avatar
4.4 gsr
The counter shaft looks good.
Old Mar 12, 2014 | 10:40 PM
narfdanarf's Avatar
Seen it a few times on the PPG 4.6. If you look back a few years ago there is a lot of info about this.
Old Mar 13, 2014 | 04:53 AM
tepid1's Avatar
Yes, that's why I said I've seen it before. The early revision gearsets had this issue. I've seen it on the early 4.4 and 4.6 finals.
The newer stuff doesn't seem to have this issue.
Old Mar 13, 2014 | 10:00 AM
locash's Avatar
We have a few older ones like this as well, never broken one yet though.
Old Mar 13, 2014 | 10:06 AM
V-SPEC 1's Avatar
Could be to tight against the counter shaft?
Old Mar 13, 2014 | 06:11 PM
bads2k's Avatar
machining problem from the older units.
Old Mar 13, 2014 | 09:37 PM
locash's Avatar
Can you get them all warrantied?
Old Mar 13, 2014 | 10:56 PM
Sorry for the noobish question, buddy. My tranny is pretty early 08-09 and god knows I've tire shook like a mfer and never seen it before. How many passes did u get before you seem this?
Question is for op and locash also. If they are willing to share.
I have notice on the gsr ring gear that it doesn't sit fluch with the diff. Had to machine the spool a couple mm smaller so it would sit flush.
Old Mar 14, 2014 | 08:57 PM
DaBeastALLBOOST's Avatar
Originally Posted by BillyEG92
4.4 gsr
The b16/LS ring ppg ring gear has more material on it because the diff is smaller.
teamasr1
Transmission & Drivetrain
Mar 21, 2010 09:31 PM
092eg6
Dec 15, 2009 07:01 PM
Black R
Aug 9, 2005 07:27 AM
91SiRX
Jul 26, 2005 04:17 PM
