May FS Thread
Old May 3, 2014 | 03:36 AM
crazes's Avatar
Moderator
Default May FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old May 3, 2014 | 05:03 AM
Blown90hatcH's Avatar
Default Re: May FS Thread
FS: ~2 gallon fuel cell. Mounts in the OEM battery/fuse box location. Comes with a -10 feed, -8 return, vent and billet fill cap.
Price = $200 shipped in the states
FS: 5 gallon aluminum fuel cell. Mounts in the factory location and bolts to the chassis so no straps are required. Comes with two -8 or -10 feed fittings and -8 or -6 return.
Price = $375 shipped in the states
FS: Brand new Golden Eagle OEM 84mm B-series vtec head gasket.
SOLD.
FS: B-Series Vtec shift linkage. Comes with urethane bushings too. Good condition.
Price = $75shipped in the states
FS: B-series LS hydro final drive. Good condition.
Price = $25 shipped in the states.
FS: B-series B16 hydro diff bearings. Brand new.
SOLD
FS: New MSD HVC Coil.
FS: Tyco Electronics/T1 75A relay for those guys running a dual Bosch 044 setup or high out put Weldon fuel pump setup. Good condition.
[Price = $25 shipped in the states
FS: Resistor boxes (2) and one hydryo VSS.
Price = $15 each resistor box or $20 for both. $15 for the VSS
Old May 3, 2014 | 05:18 AM
blade0314's Avatar
TESTING WATERS: for sale my 95mm complete shortblock, this went 10.41 @130 mph and had more in it but i built a bigger motor. i can see this little motor going a .30 once properly dialed in. this shortblock was freshend up by randy owens over this winter so everythign is fresh and brand new. it has new main and rod bearings, new thurst washers, fresh hone and pistons rings. its ready to rock. the motr consists of the following
JDM CLOSED DECK H22A
ERL SLEEVES
KS TUNED BALANCE SHAFT DELETE
NEW OIL PUMP
CARILLO H22 LENGTH RODS
CUSTOM CP PISTONS (MAX DOME/MAX COMPRESSION)
BRAND NEW OEM USDM NON VTEC PRELUDE CRANK 95MM
for more info contact me at 516 342 0318 im located in long island, ny
1. Selling my new rear bwr toe bar polished, never a used or mounted looking for 120 shipping can be arranged, text or call me at 516 342 0318 thanks located on Long Island NY
2. Oem blasted and cleaned 4.4 b16 final drive and ring gear $180 negotiable
Old May 3, 2014 | 05:59 AM
EF'n Sedan's Avatar
Brand New Wilson Manifolds 90mm Throttle Body....$300
Old May 3, 2014 | 06:22 AM
flycivicsi's Avatar
I hate to have to go in this direction but due to some changes in my life I have to get rid of one of my cars. So with that I decided to part out my drag car. I have bought and sold lots on here so buy with confidence. I can provide numerous vouches if you require. All prices are shipped and in US dollars you must pay paypal or send as a gift. I am located in Canada but do not let this stop you from buying. Do not bother lowballing me I will completely ignore them. If you don't like the prices feel free to buy elsewhere.
Text or PM only 1 306 551 5139
- Race motor brand new never used - $4000 shipped (Does not come with valve cover $200 more for that) *WILL NOT PART OUT. SOLD AS A WHOLE*
Benson sleeved LS-vtec engine (sleeved prior to benson engraving the block)
84mm bore
GRP billet aluminum rods
Custom ross 11:1 pistons w/gas ports
JE custom wrist pins
O-ring'd block and reciever grooves in the head
SCE Copper head gasket
Moroso 5qt oil pan
JG cylinder head GSR
cnc'd
ferrea bronze guides
JG .5mm oversized flat face valves
JG valve springs and retainers
fresh valve job and surface
Highly polished front of cylinder head looks amazing
Brand new skunk2 pro 1 camshafts
- B series PAR Dog Box Gearset 2.9/2.0/1.4/1.09 With a 4.4 Final drive and cuff support maybe 10 passes with brand new M-Factory Diff installed in a re-endforced case - $5000 shipped
Chase Bays CM1 Engine Harness - Honda/Acura B / D / H Series CHASSIS: 92-95 Civic | 94-01 Integra ECU/ECM: OBD1 INJECTORS: ID-2000 ALTERNATOR: OBD0/OBD1 IGNITION TYPE: OBD1 Distributor - $450 shipped
AIR Carbon Fiber intake manifold(Fits both gsr and b16 heads dual bolt pattern) - $900 Shipped
B series Carbon Fiber Valve Cover - $450 shipped
B series Oil Catch Can, Comes with valve cover, 4 lines(2 for head and 2 for block), and oil catch can - 400 shipped
Sprinwerks Slicks and Skinnies *WILL NOT SPLIT THESE UP DON'T ASK*
Fronts are 26x10x15 with bead lock(4x100 bolt pattern)
Rears Skinies are 25x4.5x15 (4x100 bolt pattern)
$1500 Shipped
Fuel System - 800 shipped
- 2x Bosch 044 with relays
- -8an Feed and return braided lines
- 5 gallon fuel cell
- Precision GT4294 journal bearing, 4" V-Band . Rated for up to 850hp, small chip in one fin *see picture* - $650 shipped plus paypal
- Garett 950hp Dual Back door intercooler(core size is 3.5"x12"x24") with 3" piping flanged for a tial 50mm BOV- The outlet piping on the front mount was squished a bit during shipping when I received it. This set up is used. - $490 shipped
- 4" Aluminum exhaust for EG Hatch, 3" vband with clams, one spot was cut for shipping purposes and will have to be re-welded or put a new vband clamp on it. There is a dent on the tip of the muffler from shipping. $400 shipped (please note the exhaust is not properly lined up for the picture
- KOYO aluminum Rad with 12" mishimoto fan and hoses with Rad cap (ALL BRAND NEW) $400 shipped
- 2.5" steel cold side piping with clamps NO BOV
Front mount intercooler roughly 20"x9"x3" (made 475hp no problem) - $150 ship will not split this up
- AZ racing GSR Girdle - $80shipped
- Eg traction bar (garage built so not the nicest) - $100 shipped
- J's Racing CF air Duct for EG (passenger side) -$125 shipped
Sorry for not having my name in all the pics. I recently packaged everything up to move but can take better picks for people who are only seriously interested. The only different from the parts now compared to when I took these pics are they are now in packaging ready to ship.
Old May 3, 2014 | 02:05 PM
SPOOLINmatt's Avatar
706-346-6024 matt.stover@comcast.net
FS: Supertech Valve Springs and Retainers....the 85lbs version
$150 shipped
FS: Ferrea Dual Valve Springs(Only)....the 75lbs version
$100 shipped
Old May 3, 2014 | 02:59 PM
89SiR's Avatar
Selling my 94 Integra Drag Car, I started this project but never had a chance to finish. This setup has never been run or even started. Requires some work and parts to finish... fuel lines, brake lines, gears, wiring, some body work. I'm not looking to part it out at this time and I am unable to deliver. Asking $16000. *Located in Victoria BC Canada*
Chassis
NHRA 8.5 or slower certified 94 Acura Integra
Drivers window safety net
Custom aluminum dash
One piece fiberglass front end
Full lexan windows
Custom Fiberglass hatch
Modified and lightened doors
Kens Kustom Chassis straight axle with brakes
Kens Kustom Chassis Wheelie Bars
Kirkey Pro drag aluminum seat with cover
Z10 traction bar
OMP Pedals and steering wheel
T1 Race Development G-Force shifter
Driveline
DSS 5.9 Axles with Hubs
Quaife LSD (B16\LS)
Liberty cuff
Competition Clutch twin disk (balanced)
Weld Magnum 15” inch Front rim (4x100) with 26” MT Drag slicks
Weld Magnum Drag Spindle Mt rear 15x3.5” with MT 22” Skinnies
Wilwood Dynalite Drag front brakes
KW Variant 3 Coil overs
Skunk2 Pro-series camber kit
Motor
Golden eagle sleeved GSR block
82mm sleeves + O-ringed
oil squirters plugged
Crower connecting rods
Aries/ Endyne roller wave pistons (Coated pistons + larger wrist pins)
Stock crankshaft
Moroso aluminum oil pan
B16 Head (port/polish & flow benched)
Crower valves, Eibach springs, Ferrea guides
Skunk2 Pro 1 cams
Ati race dampener
Toda oil gear (new oil pump)
Mezerre electric water pump
Edelbrock intake
Edelbrock 75mm throttle body (port matched to intake)
Turbo
Bullseye S374R with 1.25 exhaust
2x Turbosmart pro-gate 48 wastegate
Turbosmart Race Port blow-off
AFI front facing turbo manifold
Precision liquid to air intercooler
Custom water tank
Custom piping with Vibrant V-band clamps
Electronics
AEM ecu
AEM 4-channel K-type thermocouple amplifier with 4 pyrometers
T1 Race Development - M&W Pro14 Ignition “coil on plug” Honda CBR coils
T1 Race Development cam trigger kit
Innovate wide band
Misc. gauges
FUEL
Aeromotive Eliminator fuel pump
Aeromotive 100 micro filter
Areomotive 10 micro filter
Aeromotive pressure regulator
Skunk2 fuel rail
Injector Dynamics ID2000’s
Misc.
T1 Race Development crankcase ventilation system
T1 Race Development B Series coil cover
Avid solid billet mounts
Koyo aluminum radiator
Deist Parachute
Deist Transmission blanket
Kens Kustom Chassis staging brake
Kens Kustom Chassis clutch master cylinder
Kens Kustom Chassis brake master cylinder
Old May 3, 2014 | 06:26 PM
ls_on_boost's Avatar
No longer for sale
Old May 4, 2014 | 10:03 AM
acrite1999's Avatar
Sold
Old May 5, 2014 | 10:51 AM
sold
Old May 6, 2014 | 07:47 AM
RASE's Avatar
Everything is located in San Diego.
H22A4 Shortblock:
2001 H22A4 Shortblock. The block was attained from a Honda dealership in 2001. It was a warranty exchange on a new prelude that had a blown head gasket. Coolant leaked into one of the cylinders. The block just needs a simple bore/hone and its good to go. It comes with main caps, main studs and main girdle. I've had it for over a decade and unfortunately, I never got around to using it.
Asking $200 OBO - picked up
H22 Cylinder Head:
This head is completely bare, comes with cam caps only. The head itself is in excellent condition. A perfect core for building.
Asking $200 OBO picked up, or + shipping
J32 Type S Cylinder Heads:
These heads are completely stock and both in excellent condition. Both front and rear heads sold together. The heads are disassembled but all valves, valve springs, retainers, keepers, rocker arm assemblies, etc will be included with the heads.
Asking $300 OBO picked up, or + shipping
PM me if you’re interested.
Old May 6, 2014 | 01:59 PM
jdm inc's Avatar
tpr b series cam seals brand new 25 a pc.
b series fuel rail new. 120 shipped.
bnib 4303 fuel pump 500 shipped.
Old May 7, 2014 | 08:21 AM
vavoom's Avatar
http://hondamarketplace.com/attachme...3&d=1396094725
HP racing GSR intake 270.
T3 ramhorn 44 mm wastegate flange with 3" down pipe 680.
4" ceramic coated down pipe for topmount manifold and sx 400 turbo 250.00
ALL PARTS ARE USED BUYER PAYS SHIPPING REASONABLE OFFERS WELCOMED.
Old May 7, 2014 | 09:26 PM
RollermanDan's Avatar
Sparco racing seats and parachute have been sold! Thank you to everyone that took a look at the sale!
Old May 9, 2014 | 01:22 AM
newtype_33's Avatar
44mm wastegate dyno used only $240 shipped and paypal fee included...sold...sold...sold....sold
B-series liberty faceplated gears 1-3 gsr and 4th ctr gear ratio gearset heat treatment on gears,comes with sliders 1-2 and 3-4 gsr final drive $1200 firm plus paypal fee and shipping sold...sold....sold....sold...sold
Obx 1000hp axles dyno use only $550
Call or text 925-325-5005
Old May 9, 2014 | 02:06 PM
b16turboteg's Avatar
I have a brand new journal bearing 6766 turbo s cover with a t3 .82 ar exhaust housing with a 3" vband welded on. Decided to run a 6266 instead on my street car. I'm asking $1100 Obo.
Feel free to text me - 3603050569
Old May 9, 2014 | 05:22 PM
ltrkstr2k's Avatar
Autometer Pro Comp 4374 Electric Nitrous Gauge w/ sensor and all wiring. only used it with 1 full bottle. Think i still have the original box. Dont need it with my new setup. Looking to get
$150obo shipped
located in Delaware
Old May 11, 2014 | 09:04 PM
No longer for sale
Old May 12, 2014 | 10:16 AM
b-built's Avatar
aim digital dash comes connector and oil sensor and water temp sensor $900
spinwerks fronts and rears fronts are 13x10 rears are 15x4 powder coated centers $1400
quafie k series full dog box complete trans 2nd gear needs servicing 3200neg any questions or concerns call or text 5164037564
Old May 12, 2014 | 05:44 PM
revn9k's Avatar
Asking price: $210 obo
Contact: PM or for faster reply: revn9k@hotmail.com
Brand new, never used, never mounted.
BDL 72mm Throttle Body. Retail value $260.
Asking $210 obo negotiable. Didn't fit my application.
Fits B, D, H, F-series Honda engines.
Old May 12, 2014 | 09:11 PM
C16efsedan's Avatar
Contact: 804-337-8376
For Sale:
  • Brand NEW Crower Stage 3 Turbo/Allmotor Cams B series Part no. 63403-2 - $375
  • OBD0 Alternator - SOLD
  • Used STR Cam Gears with Big Bolts - $160
  • Precision 1000cc - SOLD
  • 15’’ Weld Magnums With 275/50/15 M/T Drag Radials (Tires have 2 miles) - $850
  • Brand NEW Crower 1mm Oversize Intake Valves and .5 Over Exhaust Valves - $275
  • Used GSR GRP aluminum rods with ARP 2000 bolts. $400
  • Reconditioned from CP, CP Pistons 83mm 9.0:1 compression. With fresh high temperature ceramic top coating and Molly skirt coating. Includes all locks, wrist pins, new ring set and spec sheet. - $500
  • New Mac Boost Solenoid with Barb and Breather Fittings. $65
  • Used Autometer Tach (2-5/8 I believe?) - $20
  • Used B&M Pressure Gauge - $20
Old May 14, 2014 | 10:31 PM
neonkid's Avatar
Old May 17, 2014 | 01:37 PM
dcmatt's Avatar
I ordered this thinking i had a bad clutch in the car. Ended up being another issue so its up for sale. Looking to get $350 that includes shipping and paypal fees
Located in charlotte nc if your local 7042583216
Old May 19, 2014 | 07:18 AM
FRernesto's Avatar
- For sale used AEM 3 port boost controller pulling off in working condition 35.00 free flat rate shipping.
- For Sale is this Borg Warner S300sx 9180 66mm turbo with a 1.10ar turbin housing. Freshly rebuilt by BW, both turbin and compressor wheels are free of nicks/damage. 650.00 will work with shipping and paypal fee's. **sold**
- For Sale is this Full-Race back door IC with BOV mounting on the end tank. This intercooler is in excellent shape no dings or dents on it anywhere. 350.00 will work with shipping and paypal fee's.
Old May 20, 2014 | 05:29 AM
AllMtrRex's Avatar
Price: 2200 OBO plus shipping
Description of item: Serial # NPR3-3001740 (EP3 CTR 6-speed LSD Transmission)
Condition: Brand new in OEM box, took out just for pictures.
Contact: Phone 336-932-2023 or Email levantimothy@gmail.com
ICB list this transmission for $2,649.97. However, it cost $2789 shipped to my address. Shipping was $139.
Technical Information straight from ICB for those who would rather not click an outside link
The link below is the exact transmission I've listed. I purchased mine through the same company.
http://www.icbmotorsport.com/dck2tyrtrbrn.html
Pictures sent to me from ICB Motorsports showing the condition and packaging before shipping can be added if needed.
Purchase Order Documentation can be scanned and uploaded if needed.
If you have any questions, please post, email or call.
