5th gear cuff
Old May 14, 2014 | 04:39 AM
89efhatchy's Avatar
Default 5th gear cuff
Which brand do you prefer? I was looking at the cnc cuff from ipg. Just wanted to ask first and make sure I get one that is straight forward.
Old May 14, 2014 | 06:16 AM
SPOOLINmatt's Avatar
Default Re: 5th gear cuff
not much difference in them.
Old May 14, 2014 | 06:20 AM
EJ1_Ex's Avatar
I'm sure they all are the same.
Old May 14, 2014 | 06:26 AM
89efhatchy's Avatar
You wouldn't think. Just wanted to make sure there wasn't any thst people had problems with fitment or anything.
Old May 14, 2014 | 07:17 AM
AZ_CIVIC's Avatar
Liberty Cuff works good for me.
Old May 14, 2014 | 08:48 AM
Honda Bull's Avatar
They are all about the same designed from the same fixed center distance. And most bearings supplied are similar, too.
One thing to watch out for is to install the cuff with JUST the mainshaft and close the case. Make sure the cuff does not contact the case by the countershaft on the inside. If it does, start making some clearance for it.
Old May 14, 2014 | 09:05 AM
Turbo-LS's Avatar
I have an MFactory in my trans. No clearence issues install is pretty straight forward on all of them though. Transmission seems to go back together easier with the cuff installed vs not which is a plus.
Old May 14, 2014 | 03:36 PM
89efhatchy's Avatar
Sweet, that's good to know. I ended up ordering the cnc cuff. Thanks guys!
Old May 15, 2014 | 02:21 AM
sonicivic's Avatar
i had to clearance my case for the cuff....pretty easy
Old May 15, 2014 | 04:40 AM
89efhatchy's Avatar
No biggie. I'm not scared to cut or grind lol
Old May 15, 2014 | 10:01 AM
poorboy44's Avatar
Got my cnc cuff from Ipg, no problems at all and awesome customer service
Old May 15, 2014 | 05:58 PM
Honda Bull's Avatar
Just looked back at some photos. The CNC was the one I had to clearance for. Just a heads up!
Old May 16, 2014 | 04:33 AM
89efhatchy's Avatar
I guess every case is a little different. I'll be sure to double check. If you don't mind, post the pics up of where you clearanced it.
Old May 19, 2014 | 02:52 AM
Honda Bull's Avatar
I don't actually have photos of the clearancing. Just the assembled gear set with the cuff on it.
It was clearanced up around where the c-clip for the countershaft is. Cases can differ by up to .020". I would put some putty on the edges of the cuff once you have the mainshaft shimmed to the thrust clearance you want, then seal the case and see where the tightest spot on the putty is to see how bad it is. Personally, the cuff should have had a chamfer to it at the edges for as thick as it was.
miahjera04
Transmission & Drivetrain
Jul 2, 2016 07:01 PM
paopao
Jun 14, 2010 10:40 AM
vacantskies88
Sep 4, 2008 02:04 PM
blkb18
Mar 17, 2005 06:33 PM
Ruby Civic
May 26, 2003 12:47 PM
