Forward facing oil drain
Old Mar 26, 2014 | 10:18 AM
Scott53092's Avatar
Default Forward facing oil drain
I just finished making my forward facing manifold for my d2b drag car. Running a holset hx35, I designed my manifold so that it left the turbo up a little higher so that I can actually get a decent drain angle. Now if I runs 90* -10 off the turbo, is that going to cause oil to "pool" like people claim, or will gravity/pressure forcing the oil out of the turbo overcome any "bends". I saw a couple companies that make 60* fittings so should I go that route? How are other people doing it?
Old Mar 26, 2014 | 11:09 AM
luck4rmkc's Avatar
Default Re: Forward facing oil drain
Any reason you see that you can't use a 45* fitting off the bottom of the turbo?
Old Mar 26, 2014 | 11:15 AM
Scott53092's Avatar
I think I have one sitting around I can check, may fit, so long as the return doesn't level out too much as it needs the oil pan.
Old Mar 26, 2014 | 11:52 AM
scottdh20's Avatar
thts about where mine sits scott...if I could do it over I'd make it a bit higher but so far so good
b00st4life
Oct 22, 2014 11:25 AM
Bigrederic
Apr 29, 2010 06:18 AM
bubbleboy22
Jun 18, 2007 03:26 PM
EJ1 wilcox
Feb 5, 2005 05:30 PM
Damon B.
Dec 14, 2002 10:27 AM
