Quest for9sec past
Old May 8, 2014 | 06:23 PM
ft/lbs?'s Avatar
Default Quest for9sec past
Build 84mm b16 block gsr head headway performance build engine 6265 billet turbo is it gonna be enough what size I/c pipe is needed etc....help please point me in the right direction I want 9.9 1/4 mile pass
Old May 8, 2014 | 06:52 PM
Turbo-LS's Avatar
Default Re: Quest for9sec past
6265-6266 makes plenty of power to run a 9 second pass. Takes practice and car setup and boost control to make it happen. Plus a good drag suspension. 2.5 hot side and 3" cold side for piping
Don't expect to just go out and run a 9. It will take time so don't get discouraged.
Old May 8, 2014 | 08:18 PM
ft/lbs?'s Avatar
Thanks man had the car forever almost gave up next thing is a decent suspension I wanna drive the car on the street sometimes I've had plenty of cars and bikes but this thing is the one I can't part with and it's just missing I/c piping and a down pipe that's it far to long for something so small it's about that time.
Old May 9, 2014 | 07:55 AM
CDecker0218's Avatar
What this guy said. You can have all the power in the world and still not run 9's. I have the same set up you have. I went 10.8@134-136mph's but I have learned ALOT since then. Good slicks, boost by gear, alignment and good suspension. Full throttle shift is going to help ALOT which is why I was not doing. Like turbo ls said, dont get upset because you wont go 9's first night out!
Old May 9, 2014 | 10:17 AM
PINKIE2's Avatar
I've gotten to 10.4 @ 138mph with about 650hp, suspension, new slicks but on a GT35R - Some tell me that 9's are not possible with that size of Turbo and others say it is possible.
I stopped listening, and I am going to focus on consistency first. Did I mention I have 90% of my interior.
Old May 9, 2014 | 10:18 AM
PINKIE2's Avatar
I meant 550hp - Oops.
Old May 9, 2014 | 03:14 PM
Turbo-LS's Avatar
Gt35 will run 9'a no problem. Just going to take some work. I'm getting closer and close to hitting 160mph which is 8 second territory with the right setup. I'll be happy if I can consistently keep shaving time off my passes and hit low 9's
Old May 9, 2014 | 03:57 PM
ls_on_boost's Avatar
damn really 160 for 8s whats the right setup
Old May 9, 2014 | 04:26 PM
xohcef's Avatar
The right set up would be to have the rear wheels driving the car as well as the fronts.
Old May 9, 2014 | 04:51 PM
ft/lbs?'s Avatar
Yeah alignment is key and suspension I had All big turbo parts on the car since all my friends were all in I was going that route but then didn't have the time now i got time and want to get it going will a precision 850hp I/c kill the car or should I swap it out with something else any input is much appreciated guys thanks for all the info keep it coming the car is a 92 Vx hatch just incase.and what suspension would you guys recommend.
Boostinb20!
Sep 10, 2008 04:45 AM
nickromeo
Apr 14, 2006 11:20 AM
NapTownSi
Feb 27, 2004 04:05 AM
Wo-Nelly
Dec 10, 2002 01:11 PM
98hx99b18c
Dec 13, 2001 09:18 AM
