Honda CR-V & Element 2WD & 4WD Element & CR-V
HELP PLEASE
Old Jun 20, 2023 | 07:53 PM
Mgonvold's Avatar
Default HELP PLEASE
My 2006 CRV has been losing power for a while it is now whistling from the engine when I accelerate and the exhaust is heating up so much it has melted the carpet in the middle of the car just behind the passenger seat. I need ideas on what it can be causing it and can't afford a mechanic.. any help will be greatly appreciated I basically live out of my car
Old Jun 20, 2023 | 11:35 PM
DCM1's Avatar
Default Re: HELP PLEASE
Sounds like your catalytic converter is plugged.
Old Jun 21, 2023 | 04:28 AM
easy129's Avatar
if you live in a state without Emissions testing you can cut out the catalytic converter and install a straight pipe. Unfortunately if they have emissions testing in your state you will have to get a catalytic converter. Aftermarket would be cheaper.
Old Jun 21, 2023 | 09:34 AM
DCM1's Avatar
A word of warning though, removing the cat will leave you with a constant check engine light, which is super annoying. If you do get a replacement cat, don’t get a cheap piece of crap otherwise it will fall apart inside, and rattle around. There are carb-compliant ones available, from what I’ve read. It’s doubtful you’ll be able to find a new factory one, beside them being probably 2 grand
Old Jun 21, 2023 | 10:20 AM
easy129's Avatar
He’s stated that he’s basically living out of his car, thus my suggestion to remove the cat. You can also try https://upsw.com/2003-honda-element-...tem-kit-kit186
