Honda CR-V & Element 2WD & 4WD Element & CR-V
110K no transmission fluid change
Old 08-27-2010, 02:06 PM
dankoty's Avatar
Default 110K no transmission fluid change
My wife's car just turned 110K and she has owned it since it was new. We recently were married and I just now found out that she has never had the transmission fluid changed. Otherwise the car is in fabulous shape and runs very well, including the tranny.
My question is - should I try to change it now or as I've heard from some people, this could really destroy the seals by putting new tranny fluid in. Any thoughts would be appreciated. Thanks.
Old 08-27-2010, 09:40 PM
92civlude's Avatar
Default Re: 110K no transmission fluid change
Leaving the fluid in there should not be an option. If the tranny goes away after the fluid change, It was bad anyway. If its a 5 speed, change it once.If its an auto, change it 3 times with test drives in between.
Old 08-27-2010, 10:36 PM
bseriescrxsi's Avatar
what you want to do as stated is 3 drain and refills....flushing the fluid can damage the trans because hondas do not have serviceable filters......do a drain and refill and drive a couple miles then repeat twice
Old 08-12-2012, 03:37 AM
HT Order of Merit
JDM_Ej's Avatar
My girlfriends CRV has almost 180k on it... we bought it with 112k and I have never changed the ATF. I have no idea if it was ever done before.
The ATF fluid isn't cheap... so 3 fluid changes? The manual shows overhaul capacity at 3.1 quarts for a change, so I will need a total of 9 quarts to complete 3 changes right?
Old 08-14-2012, 05:44 PM
HT Order of Merit
JDM_Ej's Avatar
Sooo... no one?
Old 08-14-2012, 05:48 PM
salaamq's Avatar
For sure you should change it now.
The 3 changes is new to me, I've never done an ATF change on a Honda, I'm used to GM.
My accord has 80k on it, not sure if it has ever been changed, thats how I bought it. Not trying to jack your thread, but should I do a 3x change?
Old 08-15-2012, 04:05 PM
black0hatch's Avatar
i think the idea behind the 3x change is because when you drain the tranny fluid its not gona completely train the torque converter still holds alot. so if you do it three times it will likely get all the old stuff out.
Old 08-16-2012, 06:28 PM
HT Order of Merit
JDM_Ej's Avatar
Makes sense... just expensive fluid lol.
Old 08-16-2012, 08:19 PM
el crapitan's Avatar
divorce
Old 08-17-2012, 04:45 AM
hahaha
Old 01-05-2017, 05:05 AM
Ycab's Avatar
Hi just want to check if any think knew regarding tranny oil change in Honda Accord. Just find out there is the oil filter which is replaceable. My current oil has been there for 8 years and now I need to prepare well for change, flushing. I'm glad i found your post. Thank you.
Old 01-08-2017, 03:38 PM
Resident Gearhead
BryanM.'s Avatar
grease in you elbow
el
oh
el
Tmilli55
09-26-2018 01:27 PM
Blacknight117
30
07-03-2011 07:25 AM
bmclean1
02-24-2011 08:03 PM
aries331
12-01-2007 01:13 PM
typer_801
02-05-2002 09:29 AM
Quick Reply: 110K no transmission fluid change
