Honda CR-V & Element 2WD & 4WD Element & CR-V
AC compressor noise in '04 Element
Old 09-22-2015, 02:22 PM
Hernst's Avatar
Default AC compressor noise in '04 Element
A whiny noise, like an electric drill, started coming from the A/C compressor on my O4 Element when the A/C is turned on or cycles on. The noise increases in volume with engine rpm. I suspect the A/C clutch-pulley bearing or the compressor bearing.It only makes noise when the A/C is engaged so I suspect the A/C compressor bearing.
However, I've read that 90% of the time its the A/C clutch-pulley bearing and would prefer to not have to open the system by replacing the entire unit if I can avoid it.
Is there away to rule out one or the other?
gooeymax
08-30-2018 04:33 AM
the soL that could
08-15-2011 02:54 PM
HGZ
05-29-2008 12:51 PM
Azn Kenny
10-08-2007 01:55 PM
HONDA_TYPE_R
Acura TL, RL & ZDX
09-20-2006 06:51 PM
Quick Reply: AC compressor noise in '04 Element
