More stalling problems
Ok so iv been working on my moms crv.. Itll drive until warm up or at idle it jus dies
Things iv replace
Ignition switch replace (dealer recall)
Fuel pump
Fuel filter & air filter
Replace the ignition cylinder w/new keys
Ignitor replace
After i swap the ignition/key cylinder it idke for a few and the check light came on
I hook up my reader came up with p1336
Thats the crank sensor right? Im thinkn of doing the bypass trick
Plz lmk watcha guys think..
Things iv replace
Fuel pump
Ignitor replace
P0336 Honda - Crankshaft Position Sensor 'A' Circuit Range/Performance
Possible causes
- Faulty crankshaft position sensor
- Crankshaft position sensor harness is open or shorted
- Crankshaft position sensor circuit poor electrical connection
- Signal plate may be damage
- Starter motor may be faulty
- Starting system circuit
- Dead or weak battery
P1336 Honda - Crankshaft Speed Fluctuation Sensor Intermittant Interruption
Possible causes
- Faulty Crankshaft Position Sensor
- Crankshaft Position Sensor harness is open or shorted
- Crankshaft Position Sensor circuit poor electrical connection
Possible causes
Possible causes
What do you mean the toothed ring? Yes im actually fixn to check the signal source.. If the plug is bad i have couple laying around ill jus replace the plug.. That wud work right if the plug is bad
Things iv replace
Fuel pump
Ignitor replace
Things iv replace
Fuel pump
Ignitor replace
I'm having the same stall problems. Thinking of replacing the Crankshaft sensor next. Did you ever do this? And did that work? I'm just lamenting the job I'll have to hire someone to do to replace it. Honda doesn't make it easy. You have to remove wheel, all belts, open timing belt, just to get at it.
mar7pau
Aug 29, 2010 10:34 AM
Sewer Rat
Acura TL, RL & ZDX
Mar 27, 2006 10:56 AM
