Honda CR-V & Element 2WD & 4WD Element & CR-V
2006 Honda CRV headlight relay
Old 02-19-2015, 09:22 PM
sam27's Avatar
Default 2006 Honda CRV headlight relay
Hello,
Can someone tell me where the relay for the driver side headlight relay is located in the fuse box? Is it located in the fuse box under the hood? Thanks for your help!
Sam
Old 02-19-2015, 09:25 PM
Global Moderator
tech8's Avatar
Default Re: 2006 Honda CRV headlight relay
Headlight relay 2 for the driver's headlight is located in the under-hood fuse/relay box.
Old 02-20-2015, 06:33 AM
sam27's Avatar
Thank you Tech8.
Can you please indicate the location of the relay on the image? Thank you.
Sam
Old 02-20-2015, 07:27 AM
Global Moderator
tech8's Avatar
Headlight relay no. 2 is right above the large fuse no. 20. You should be able swap a relay to check whether the relay is okay or not. Many of those relays in the under-hood fuse box should be the same type (look at the specs. on them).
Old 03-10-2016, 02:18 PM
Jdmintegr's Avatar
Those relays are for high beam, i am also having the same issue i was told the headlight relays are under the dash...??
Old 03-10-2016, 04:24 PM
Global Moderator
tech8's Avatar
You're incorrect. For a 2006 CR-V, headlight relay 1 (for right side hi and low beam) and headlight relay 2 (for left side hi and low beam) are both located in the under-hood fuse/relay box.
Philip Smith
10-20-2021 04:46 PM
eddygp
10-02-2010 07:57 PM
stocker2shocker91
08-18-2007 10:52 PM
goofyej6
06-26-2005 09:14 PM
Quick Reply: 2006 Honda CRV headlight relay
