Honda CR-V & Element 2WD & 4WD Element & CR-V
HELP PLEASE!!!
Old Apr 4, 2015 | 04:56 PM
E DAWG's Avatar
Icon6 HELP PLEASE!!!
I have a 2000 CRV its throwing me some codes that I cannot find explanations for online. Doe's anyone have any idea? I would troly appreciate it.
61-01 & 15-01
Thanks for your time
Old Apr 4, 2015 | 05:18 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: HELP PLEASE!!!
What codes is it throwing? The code should begin with a "P".
Old Apr 5, 2015 | 02:02 AM
UK-Kev's Avatar
61-01 & 15-01
Hello,
It seems you are quoting CHECK engine light flashes!!! You will need to confirm how and with what tools / equipment you are diagnosing your CRV problems, due to the different fault codes system being used.
Codes systems.
1/ CHECK engine light flashes
2/ ODB1
3/ ODB2
4/ ABS fault codes
5/ Transmission fault codes.
Kev
Old Apr 5, 2015 | 06:07 AM
E DAWG's Avatar
These are codes that are coming from a scanner my friend has.
Old Apr 5, 2015 | 06:10 AM
DO IT ON ALL FOURS
Go to a local auto parts store and get them scanned for free.
Old Apr 5, 2015 | 06:11 AM
E DAWG's Avatar
Car doctor M.D.
Old Apr 5, 2015 | 06:42 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Those are probably ABS trouble codes, which can be read with a scanner. Is your ABS light on?
DTC 61: Ignition voltage
DTC 15: Right-rear wheel sensor (open/short to body ground/short to power)
1. For DTC 61, issue can be due to faulty ABS control unit. But, check under-dash fuse no. 15 (7.5A), charging system, and battery.
2. DTC 15 may be due to wring or right-rear wheel sensor. Issue may be related to DTC 61.
shortlid
Mar 15, 2006 05:04 PM
OutlawCL
May 15, 2005 04:59 AM
Prelussion
Aug 5, 2001 11:10 AM
