Measuring Runners ITB's
Old Mar 9, 2005 | 02:27 PM
ferio 95's Avatar
Default Measuring Runners ITB's
Ok i picked up a set of itbs and am almost done just need to double check my runner length. basically im asking for opinions on the length
Old Mar 9, 2005 | 02:55 PM
RCautoworks's Avatar
Default Re: Measuring Runners ITB's (ferio 95)
Measure the length from the flange to the very end, and tell us how long it is. Then tell us how much length you have from the head ( on the engine ) to the firewall, those look pretty long and I would just be worried about them being really close to the firewall.
Old Mar 9, 2005 | 03:56 PM
ferio 95's Avatar
Default Re: Measuring Runners ITB's (90blackcrx)
8 1/4 " from flange to tip of the itbs
about 13 1/2 " from valve cover to the fire wall
Old Mar 9, 2005 | 06:47 PM
ferio 95's Avatar
more pics
Old Mar 9, 2005 | 07:40 PM
97EK9hatch's Avatar
how much you pic those up for, and what kind are they? they look sweet
Old Mar 9, 2005 | 07:42 PM
ferio 95's Avatar
Default Re: (97EK9hatch)
these are Honda CBR 954 rr itb's. reason behind choosing these perticular itbs is that they use honda tps and map sensors. cost me 100 bux so far. still need to buy a vacuum manifold. i could make one but its only 35 bux.
Old Mar 9, 2005 | 07:44 PM
97EK9hatch's Avatar
thats sweet... and all you need is the adapter plate and runners from it to the ITBs? if so, i have plans...
Old Mar 9, 2005 | 07:45 PM
ferio 95's Avatar
well you have to make a setup to run iacv, idle screw, and throttle cable but its really easy as hell to do
Old Mar 9, 2005 | 07:47 PM
97EK9hatch's Avatar
nice, thanks for the info
ferio 95's Avatar
ima post up the finished product here in a few days and explain what all is needed since no one else did a good job of it
Old Mar 9, 2005 | 07:48 PM
97EK9hatch's Avatar
wait, and the "adapter plate" you have (as i look closely) is nothing more than an intake manifold that you cut the tunnle off of?
Old Mar 9, 2005 | 07:49 PM
ferio 95's Avatar
yup. some people do sell flanges to do it that way but thats only helpful if you use gsxr itbs which can be spaced out perfect
the 954 rr itbs are about 2-3 mm off on each outside runner
Old Mar 9, 2005 | 07:56 PM
97EK9hatch's Avatar
oh.. ok, ok... looks cheaper to just use a stock intake mani and cut it... i think id go that rout for the true DIY look... haha
Old Mar 9, 2005 | 08:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97EK9hatch &raquo;</TD></TR><TR><TD CLASS="quote">thats sweet... and all you need is the adapter plate and runners from it to the ITBs? if so, i have plans...</TD></TR></TABLE>
Search around, a lot of threads on it. You really need a wideband to tune it with
Old Mar 10, 2005 | 09:56 AM
ferio 95's Avatar
Default Re: (90blackcrx)
ill be getting it tuned with my cam gears on the dyno pretty soon. and as far as the other threads only one ive seen was worth a damn but still lacked a few key things.
Old Mar 10, 2005 | 09:58 AM
Default Re: (ferio 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">ill be getting it tuned with my cam gears on the dyno pretty soon. and as far as the other threads only one ive seen was worth a damn but still lacked a few key things.</TD></TR></TABLE>
What kind of fuel management system do you have though ? Also is seems like you have pretty good firewall to itb clearance. And there are atleast 5 threads out there that really talk about itb's.
Old Mar 10, 2005 | 10:12 AM
ferio 95's Avatar
im running Crome. my tuner makes more power on it then AEM EMS or Hondata. He made 271 sae corrected whp on a all motor hatch back this same motor made 8 less hp on hondata
*Boostwerks*
Welding / Fabrication
20
May 20, 2007 08:05 PM
JustHere4ADay
May 20, 2007 11:25 AM
TURBOFTW
28
Feb 17, 2006 07:28 AM
RoaringTurtle
Mar 2, 2005 01:01 AM
95IntegraGSRAZ
Feb 24, 2004 08:12 AM
