F23 header flange
Old Oct 17, 2005 | 04:22 PM
luv2drivecrx's Avatar
Default F23 header flange
Hey guys, Im looking for and specs or dimensions for a exhaust manifold flange. Im planning on making a homemade manifold for a turbo application but need the proper dimensions of the flange for a SOHC F23 non-vtec including a sugestion on the thickness of the flange i should use. Any info would be greatly appriciated
Modified by luv2drivecrx at 8:37 PM 10/17/2005
Old Oct 19, 2005 | 01:03 AM
raceACCORDingly's Avatar
Default Re: F23 header flange (luv2drivecrx)
f23 and f22b1/b2 have the same header flange.
PM "weirRacing". He sells the f22bx header flange for $33.
Old Oct 21, 2005 | 12:18 PM
weiRtech's Avatar
OG Fabricator
Default Re: F23 header flange (raceACCORDingly)
if that is true about the pattern being the same, i can hook you up. click my sig that says "flanges" i have one in stock at the moment. price is $33 for the flange, shipping is $5 for any order. all my header flanges are 1/2" thick mild steel.
aaron
Old Oct 23, 2005 | 08:03 AM
Diego Dangers.'s Avatar
i have a partly built manifold you can have for 100 , come with all elbows and tees and an elbow for the wastegate. head and t3 turbo flange. one elbow and one tee are welded so far.
808DB1
Welding / Fabrication
Feb 22, 2008 05:04 PM
vtec_lude
Jul 2, 2007 02:23 PM
luv2drivecrx
Oct 19, 2005 02:14 AM
ruzzy7
Nov 22, 2004 01:48 AM
FyReo3
Jul 9, 2004 08:27 PM
