Honda S2000 Honda S2000
Tranny problems
Old Mar 30, 2011 | 04:55 AM
hondasi94's Avatar
Default Tranny problems
Last night i was crusin around in the s2k and i was going from 5th gear getting ready to shift into 6th, when it wouldnt let me...so i was wondering if anyone could tell me what would be wrong?
Old Mar 30, 2011 | 06:04 AM
Black S2K's Avatar
Default Re: Tranny problems
so it just didnt go in that one time or it wont go into 6th from that point
Old Mar 30, 2011 | 06:08 AM
hondasi94's Avatar
It wont go into 6th at all and its hard to get it into 1th and the rest of the gears too...
Old Mar 30, 2011 | 06:12 AM
Black S2K's Avatar
bleed ur clutch, check ur trans fluid/change it
Old Mar 30, 2011 | 06:18 AM
hondasi94's Avatar
Is that what you think is wrong with it? cause post the same thing up on another forum and the guy said it has to be the clutch or flywheel or even the tranny itself.. But i really dont know
Old Mar 30, 2011 | 06:42 AM
Black S2K's Avatar
it sounds like ur clutch isnt engaging/disengaging what year and miles is ur car. the master clutch cylinder likes to leak in ap1's with miles. u could be low on fluid, air in the line or maybe the mast or slave cylinder is going. check all that **** first if everything is ok then there could be something wrong with the clutch itself or maybe ur trans is just ready to take a ****
Old Mar 30, 2011 | 06:57 AM
JulieU's Avatar
Curious... do you skip gears a lot?
Old Mar 30, 2011 | 07:23 AM
Papolito's Avatar
Had the same issue when i first bought mine back in the day.
+1 on fluid
Old Mar 30, 2011 | 08:28 AM
ReddotsS2K's Avatar
It might not be the problem, But you should start there before you start pulling the car apart. Check all fluids and bleed accordingly. If that fails then come back for the next step.
Old Mar 30, 2011 | 05:22 PM
hondasi94's Avatar
Its a 02 with 67,xxx miles, ill try changing the fluids this week or weekend... Just trying to figure this out before Import Alliance in April... Thanks for the advice.
Old Mar 31, 2011 | 11:57 AM
hondasi94's Avatar
Okay well i got off early today, so i decide to pull the tranny and discover that my clutch and flywheel are **** up... Thanks for the advice.
Old Mar 31, 2011 | 02:25 PM
Black S2K's Avatar
gl
Old Apr 3, 2011 | 06:06 AM
hondasi94's Avatar
Ive been looking at a ACT Heavy Duty Clutch Kits and a ACT XACT StreetLite Flywheel. Has anyone run those before, and do they hold up? jw im trying to find a clutch that has smooth engagement and quiet operation...
Old Apr 3, 2011 | 07:42 AM
Sikocivic's Avatar
I have the ACT clutch with the stock AP1 flywheel in my 02. Its turbocharged and the clutch holds fine. It does have a heavy clutch(takes more effort than stock) but its not that bad.
Pinarr
Sep 10, 2012 11:14 AM
Khamera
Transmission & Drivetrain
Oct 28, 2008 03:41 PM
Shiftandgo
Oct 5, 2008 09:57 AM
getupoffthatthan
35
Dec 24, 2007 02:23 PM
sik96teg
Honda S2000
Jan 28, 2007 11:33 PM
