Honda S2000 Honda S2000
engine
Old Aug 2, 2011 | 03:10 AM
motorcer90's Avatar
Default engine
Need to replace my engine and need to know if anyone has ever ran a jdm f20c with usdm ecu and everything worked out fine. I rather pay the same price for the jdm engine and get a trans to if it works.
Old Aug 2, 2011 | 07:56 AM
ediesel@gmail.c's Avatar
Default Re: engine
Ive been running a f20c in my ap1 (with usdm ecu) for about a year and a half now with no problems. I do know that the f20c block is going to need the KNOCK SENSOR from the usdm block. Also when i first ran my jdm engine i was worried about the lower octane (us premium) creating detonation, but so far the engine has been running just fine on us gas.
The jdm engine feels like it has a little bit more torque than the usdm to me.
hope this helps
Antonio
Old Aug 3, 2011 | 09:01 AM
motorcer90's Avatar
Default Re: engine
no check engine light or codes?
Old Aug 3, 2011 | 10:02 AM
Boots's Avatar
Default Re: engine
technically speaking, all s2k motors are JDM...they only made that car in japan, so i dont see it being an issue honestly...
Old Aug 3, 2011 | 02:32 PM
Default Re: engine
Not swap related.
Old Aug 3, 2011 | 02:34 PM
Default Re: engine
I disagree. the f20c1 was never available to the Japanese market. (has lower compression and knock sensor).
Old Aug 3, 2011 | 05:20 PM
Boots's Avatar
Default Re: engine
regardless if you disagree or not, you're wrong...all s2k motors were made and assembled in japan, therefore, all s2k motors are technically JDM...doesnt matter what markets got what..they all came from japan...and "technically" was the key word there guy
Old Aug 3, 2011 | 06:48 PM
HondaKyle's Avatar
Default Re: engine
you understood the question and wasted a post ^
Old Aug 4, 2011 | 03:01 AM
motorcer90's Avatar
Default Re: engine
anyone know info related to the swap? trying to get the s2000 back on the road as soon as i can.
Old Aug 4, 2011 | 03:15 AM
HondaKyle's Avatar
Default Re: engine
Swapping the JDM motor in? Why not get a OEM USDM motor then? I'm sure it would be cheaper. If I'm not mistaken the JDM S2000 has 250 crank horse. They also have better gas.
Old Aug 4, 2011 | 05:14 AM
motorcer90's Avatar
Default Re: engine
find me one cheaper and i will buy it. usdm just the engine is as much as a jdm engine and trans.
Old Aug 7, 2011 | 03:09 AM
Lsos's Avatar
Default Re: engine
JDM = Japanese Domestic Market
Anyway, I put an EDM engine into a USDM car (with USDM computer) if that means anything...
Old Aug 7, 2011 | 03:24 PM
dagle's Avatar
Default Re: engine
same ****, shouldn't have a notable difference in power either unless if your *******'s more sensitive than a ****.
newtuner
Nov 12, 2007 12:39 PM
SoHc94
Aug 22, 2006 11:07 AM
94lsboost
Oct 27, 2003 03:16 PM
-Darren-
Jan 6, 2003 05:58 PM
