Honda S2000 Honda S2000
Alignment settings
Old Mar 16, 2011 | 08:39 PM
lucky13AP2's Avatar
Default Alignment settings
Hey guys i recently put new wheels on my S2, I put Enkeis RPF1s Fronts 17x8+45 and the rears are 17x9+35, im running stock tire sizes and i rolled both front and rear fenders, i tried doing a search for the Euro specs but had to luck, ive seen people running -3 degrees for the rears but nothing for the front.
I would appreciate it if someone can post the link for the euro specs or if you guys can tell me your set up if possible.
thanks in advance
Old Mar 16, 2011 | 08:42 PM
Boots's Avatar
Default Re: Alignment settings
im running -2 camber on all four corners
Old Mar 16, 2011 | 08:48 PM
dagle's Avatar
google it and see what the consensus is, a quick google showed:
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6° 45"
Caster Right 6° 45"
Camber Left -1° 00"
Camber Right -1° 00"
Toe Left 0° 0"
Toe Right 0° 0"
Total Toe 0° 0"
Rear
Camber Left -2° 00"
Camber Right -2° 00"
Toe Left 0° 20"
Toe Right 0° 20"
Total Toe 0° 40"
Im planning to run -3 camber all around, but i'll leave it up to fitment to see if I need help either way. I'm gonna get toe as close to 0 as possible and caster isn't a concern haha.
Old Mar 17, 2011 | 12:05 AM
vain's Avatar
are you lowered? if so, for that size, i'd probably do -2 front.. and try for -2.5 rear (but most likely, you'll end up with -3). for toe/caster, i just go with UK spec.
are you getting it done at Auto Innovation?
Old Mar 17, 2011 | 06:53 PM
lucky13AP2's Avatar
ill be getting it done at a local tire shop here in tracy. thanks for the specs silas and for everyones inputs. im about to look up auto innovation
b16a4
Suspension & Brakes
Aug 31, 2007 10:21 AM
Francesco
Honda S2000
30
Nov 23, 2006 03:56 PM
paz92ls
Oct 17, 2003 05:18 PM
Mugen Hamster
Jul 4, 2003 08:58 PM
qbsi
Jun 15, 2002 02:00 PM
