Honda S2000 Honda S2000
06 s2k getting code p2183!
Old Apr 27, 2011 | 05:16 AM
miguel329's Avatar
Default 06 s2k getting code p2183!
o6 s2000 30,000 miles getting code p2183(p2183 colant temp sensor 2 ckt range/perf.. where is it?), comes up on my scaner 1 0f 2 and 2 of 2.. had code p0111 changed the air filter went away.. what should i do fix the p2183 code thanks for any help!!
Old Apr 27, 2011 | 05:41 AM
TheAsian's Avatar
Default Re: 06 s2k getting code p2183!
Either coolant temp sensors are out of range, if your scan tool is capable of reading coolant temp make sure they are both in range.
With the engine cold make sure ect 2 is ambiant temp. Start and let it idle for about 5-10min ect 2 should be about 129 degrees. If it is less then its probibly bad.
Ect 2 is at the bottom of the radiator by the lower hose. That's the most likely cause of your code. Check the wiring for corrosion also.
Old Apr 27, 2011 | 08:29 AM
miguel329's Avatar
thanks i will check it out
Old Apr 29, 2011 | 06:21 AM
miguel329's Avatar
cleaned conection, made sure wire wasnt loose... reset code came back few days later.. have no way test it guess buy new one. looks like i need drain fluid to put in.
Old Apr 29, 2011 | 06:22 AM
miguel329's Avatar
should i get a oem one or advanced auto one be fine?
Old May 3, 2011 | 09:36 PM
opc's Avatar
opc
advanced auto is fine..
Old May 5, 2011 | 07:25 AM
miguel329's Avatar
thanks man... guess get sensor this week lol been broke. damn gas prices.. and bills hitting me all at once... gonna stop by dealer for coolant, my cousin telling me some additives in coolant can cuase water pump to corrode or some ****... says honda coolant is made for are cars...
JKGONZALEZ3
Jan 19, 2007 11:00 PM
B6tizzleHatch
Dec 4, 2006 10:55 AM
mprelude
Jan 10, 2005 11:52 AM
MPALUGHI
Jan 7, 2005 05:11 AM
crx_91si
Jan 22, 2002 05:06 PM
