Honda CR-V & Element 2WD & 4WD Element & CR-V
ABS Issue
Old May 25, 2013 | 06:11 PM
Jammink9's Avatar
Default ABS Issue
Can anyone advise what I need to do when the ABS light on 03 Element is lit with new brakes and rotors being put on and no error code showing when checking on a scan tool.Thanks for any help.
Old May 26, 2013 | 05:07 AM
Almighty-Si's Avatar
Default Re: ABS Issue
If the ABS light is lit there is a stored code. Your scan tool probably can't read it. I would take it to the dealership.
Old May 26, 2013 | 03:03 PM
Sticker Bomb's Avatar
Most readers that you buy will only read engine codes, they don't do ABS, SRS, BCM. You need to have a good one like from snap on, mac tool. They cost a **** load. The one I use at work is $7500, but it does everything, and we have 2 of them.
Best bet is go to the dealer or a shot that can read them. It's most likely a wheel speed sensor that is gone now since you've done the brakes, which can happen very easily if your not careful enough and hit it or broke a wire.
Old May 26, 2013 | 07:08 PM
Jammink9's Avatar
Appreciate the advice.
Old May 26, 2013 | 07:11 PM
Black R's Avatar
25 Year Member
You can jump the jumper and it'll show the abs code too.
mr_munro
Mar 14, 2012 11:53 AM
ReadySetGo
Jan 23, 2010 09:15 AM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
96integraGSR
Dec 27, 2005 03:27 PM
MK Ultra
Jul 1, 2002 11:21 PM
