Radiator Problem
Dear ,,,
Yesterday i was driving my CRV 2008 model,, suddenly i feel that AC is not cooling, i tried two or three times switch on & Off the AC but it didnt work,,, than i look at the temperature bar it was rising, i got surprised i switched off the AC and tried to stop,,, as i was on the main road it was rush hour,, after a while i managed to stop and check the radiator,,,,, it was empty and the attached bottle was also empty. i got shocked ,,, i started the vehicle and put water in the radiator,, after waiting for some time ,,, i move my car and reached the destination,,,, on second day i again check the radiator ,,, but water was full,,,,
can u suggest what should i do,,,,,,one thing more should i use coolant or distilled water for the radiator now.
Thanx & Regards,,
Ali
Thanx & Regards,,
Ali
Last edited by Ali Raza; Jun 13, 2013 at 10:13 AM. Reason: want to add some more text
Take it to a shop to get checked out. You have a leak somewhere.
You don't want to run water at all if it gets cold where you are, because it will freeze, and it will crack the engine block.
OverkillSD
18
Jul 23, 2009 01:46 PM
