Honda CR-V & Element 2WD & 4WD Element & CR-V
weird front end bouncing??
Old Oct 3, 2013 | 12:05 PM
FeedBack159's Avatar
10 Year Member
Default weird front end bouncing??
When I get over 35 mph my front end seems to shake. Almost like the wheels are unbalanced or uneven. i swapped the spare tire for each of the wheels to try to pin point of one of the wheels was unbalanced. but i still have the problem. im lowered and tires have some camber ware. Any ideas??
this is what happend
i drive home from school. got home everything seemed fine. left my house a few hours later start driving and it was shaking really bad. pulled over looked at the sway linkages. get back it it wasn't as bad. went home tightened all the suspension parts. my tires do have a little camber ware tho but i was driving fine on them fine before.
Old Oct 3, 2013 | 03:34 PM
swordofdoom's Avatar
Default Re: weird front end bouncing??
Are you using a camber kit>? That is the question.
Old Oct 3, 2013 | 05:19 PM
.turd's Avatar
Maybe something is loose.
Old Oct 4, 2013 | 05:00 AM
blackskunk2si's Avatar
does it change when you let off the gas?
Old Oct 4, 2013 | 08:17 AM
10 Year Member
only a camber kit in the back. and its less noticeable when i let off the gas. you can feel the shaking in the car, pedals, and steering wheel.
Old Oct 4, 2013 | 08:22 AM
ap1jnky's Avatar
Got a back alley garage to balanced my fronts and shook like crazy.... took them to local firestone and they did the job right the one wheel weight was way off after they got done rides super smooth.. Might be something to look into.
Old Oct 4, 2013 | 08:25 AM
10 Year Member
did your car have the same symptoms?
Old Oct 4, 2013 | 08:26 AM
10 Year Member
and it wouldn't make much sense because ive been driving on these tires for about a year. did rotations and everything. and they were running smooth the other day..
Old Oct 4, 2013 | 08:27 AM
ap1jnky's Avatar
Yep anything over 40-50 shook steering wheel pedals the works
Old Oct 4, 2013 | 08:28 AM
ap1jnky's Avatar
Yea your case is odd than
Old Oct 4, 2013 | 08:30 AM
ap1jnky's Avatar
Bent rim would diff cause this... bubble in tire??
Old Oct 4, 2013 | 08:48 AM
10 Year Member
Nothing unusual on the tires. Pretty much always have looked how they look so no unusual tire marks/ware beside the camber
Old Oct 4, 2013 | 10:01 AM
kiseliok's Avatar
I have a slight shake around 20mph, goes away around 25.
Started happening after both front axles were replaced. :/
Old Oct 5, 2013 | 03:12 PM
10 Year Member
so i did a tire balance and it really didn't help much..
Old Oct 5, 2013 | 09:46 PM
www.megameet.org's Avatar
Blown strut maybe
Old Oct 11, 2013 | 10:04 AM
10 Year Member
Update.
55mph seems okay. Annoying over our while accelerating car shakes. What could this be? It almost feels like it shakes left and right. Could it be motor mounts? Help!? I need this car
Old Oct 11, 2013 | 10:09 AM
noname87's Avatar
tie rods are solid?
Old Oct 11, 2013 | 10:14 AM
10 Year Member
Everything seems solid
Old Oct 11, 2013 | 12:20 PM
PhilStubbs's Avatar
Only thing left I can see is an axle about to let go. How are the boots at the axle ends?
Old Oct 11, 2013 | 12:30 PM
10 Year Member
Also seems like it takes left turns without shaking. But while going straight or left it shakes
Old Oct 11, 2013 | 12:37 PM
EF9_TryMe's Avatar
Have you checked the axle nuts to see if they are tight ?
How about the wheel bearings ? Grab the bottom, and top end of the tire and shake it back and forth to see if you have any play.
Old Oct 11, 2013 | 01:04 PM
10 Year Member
Axle nuts are in same position as always. Didn't get any odd play out off shaking the wheel.. this is driving me crazy!
Old Oct 12, 2013 | 01:43 AM
10 Year Member
I took the front driver side where off pushed and pulled at the axle. It was the problem.. I swear I checked that like 4 times. Took it apart. Bearing exploded inside. Replaced it everything is great now!
Old Oct 12, 2013 | 09:13 AM
kiseliok's Avatar
Great news!!
Old Oct 12, 2013 | 11:12 AM
10 Year Member
Thank you all!
