Honda CR-V & Element 2WD & 4WD Element & CR-V
master power window switch
Old Aug 29, 2013 | 10:52 AM
jayjazmin's Avatar
Default master power window switch
Hey guys, sorry for all the threads on here asking for help. Just been trying to fix things on my own with your guys help rather than taking it somewhere to get it fixed. Im failrly new to this n still dont have a manual! Anyways.. on my master power window switches, all switches work except for front passenger window switch.. is there individual fuses for this? And how do I take it out? If its not fuse then someone help me figure out what it is! Thanks everyone
Old Aug 29, 2013 | 12:24 PM
looking4vr's Avatar
Default Re: master power window switch
Are you sure it's the switch and not the window motor? Is there any noise from the door at all when the switch is activated?
Old Aug 29, 2013 | 12:27 PM
Skillachie's Avatar
In most cases its the motor like looking4yr says
Old Aug 29, 2013 | 01:24 PM
kiseliok's Avatar
Yea, those should not be individual. One fuse.
My driver's window is barely going up now. Don't know what to do with the stupid thing. I have a feeling it's going to quit on me soon.
Old Aug 29, 2013 | 01:26 PM
jayjazmin's Avatar
Is there a seperate motor for window to master power window switches? I assumed its just the switch since the window goes up n down pretty easily though thaxtual switch on door
Old Sep 4, 2013 | 10:27 PM
swordofdoom's Avatar
I had this problem along with the rear passenger window not going down.
There is a plug at the drivers side front door that has all the wiring running into it.
Its that rubber wiring sticking outside the door and running into the cabin. Mine had 2 broken wires which caused the windows to never roll down or up. I had to re-solder them at the pins since thats where it broke. Yours may have this problem as well. It unplugs easily and just pull back on the rubber housing to see if any of the wires are broken.
Old Sep 5, 2013 | 07:18 AM
jayjazmin's Avatar
Hmmm anyway you can take a pic of location?
Old Sep 6, 2013 | 01:39 AM
Its not that difficult to locate. Just pop open your door and its the only rubber hose looking thingy attached to the door that is 1" wide. This feeds all the wires into the door itself from the cabin.
Pauly321
Dec 2, 2016 12:15 PM
mayurji1
Jun 9, 2014 03:49 AM
runninclean
Mar 29, 2010 02:15 PM
Terabass
Jun 12, 2007 02:29 PM
Siegfried
Nov 25, 2004 12:13 AM
