Honda CR-V & Element 2WD & 4WD Element & CR-V
Finally! Rear alignment - Compensator arm/bolt
Old Jul 1, 2014 | 12:42 AM
shermanyang's Avatar
Default Finally! Rear alignment - Compensator arm/bolt
So since I got back from EDC Vegas and had a week left of my vacation, I decided it was time to tackle my rear toe alignment demons!!
Yup....that bish is stuck in there!! Not even a budge. Don't worry...I had 4 jack stands holding up the car
Next...used a Dremel to cut that part that holds the bearing
Now...the only thing left is the seized bearing on the bolt...gotta rip off that top sleeve
Okay...Cut off bushing outer sleeve and rubber, left the inner sleeve on, torched that bish, now I can loosen it... but it's that ******* inner sleeve that's seized! Time to cut that bitch off too!
There it is....finally off!
Went to the local ACE HARDWARE store and grabbed me some new automotive grade bolts/washers!
New Roca compensator arms and new bolts in!!! FINALLY!!
Oh...and while I was at it, I also swapped out the trailing arm bushing...cause this is what it looked like =/
Tomorrow....the other side!!!
Old Jul 1, 2014 | 04:43 AM
dogbiscuit's Avatar
Default Re: Finally! Rear alignment - Compensator arm/bolt
I did my bushing not too long ago and they looked amazing compared to those.
I'm so glad it snows only a couple of times a year here.
Old Jul 1, 2014 | 06:17 AM
qwik2k2z24's Avatar
Now that's dedication! Props!
Old Dec 30, 2017 | 04:33 PM
wxman94ej1's Avatar
Hey thanks for posting this! Did you just use the regular Dremel metal cutoff wheel? Besides taking awhile and some careful maneuvering, was it fairly straightforward to slice through all of the metal sleeves in the bushing? Any tips you can offer? Just got a Dremel for Christmas and will probably tackle this job soon. Thanks!
young_tuner
Jan 22, 2010 05:29 AM
project-boosteD
Suspension & Brakes
Jan 27, 2009 01:58 PM
gunnis
12
May 24, 2006 08:40 PM
alwaysoverkill
Suspension & Brakes
Jan 13, 2006 07:43 AM
