Ignition issue; Ignition fires once then stops firing.
2000 Honda CRV DOHC 2.0 B20Z2 Engine
It was running great after a 95% engine overhaul that I did after it over heated.
It has a rebuilt head, rings, inserts, mains, front seal, timing belt, etc.
The engine came up and ran great. I test drove it for about 25 miles at various conditions. It was flawless.
After the test driving I visited the local pub then a friends, still no problem.
I shut the engine down at the friends and when I tried to start it ..... no dice.
The next day I returned to my friends and it started immediately. Sounded great.
I drove it home and began looking for the problem.
I went through all the obvious systems.
Fuel, Air and ignition.
All seemed fine so I started it.
After the engine reached operating temp it was still running fine.
I checked timing - dead on...
I shut the engine down and it wouldn't start again.
I checked everything again. No problems.
Still wouldn't start.
I reconnected the timing light and noticed that it would only fire once then stop firing.
I assumed it was the ignition system so I changed the coil and the ICM.
The cap, rotor and wires are new and check out.
It still only fires once then quits firing.
Any Ideas???
Any Ideas???
Stan Norred
Honda CR-V & Element
12
02-06-2014 04:52 AM
