Lighting HID/Xenon kits, Retrofits and Associated Topics
Dull lighting
Old Sep 1, 2009 | 05:58 PM
GetEfdupEH's Avatar
Icon6 Dull lighting
Hey all,
I just replaced my headlights with some h4 super plasma piaa lights...
I bought these because my headlights were fine prior to this its just my driver side headlight was dull or weak whatever youd like to call it...
So I thought it was the headlight going and I threw in the h4 super plasmas and the problem is still there...
I just dont know what would make the beam appear dull?
-Its not the bulbs and the wiring is fine Ive never touched it
I just dont get it, could it be my corner light possibly going that would cause this?
I have a 1994 honda civic dx bubble if it helps...
Someone literally please shed some light on this subject...
GetEfdupEH's Avatar
Default Re: Dull lighting
please help ht this is ridick
Old Sep 2, 2009 | 02:06 PM
chawski's Avatar
try swapping the bulbs to see if the problem moves to the other side or still remains. if they problem still remains, its either one of 2 causes. 1) your lense is clouded and blocking light from passing through or 2) youre wiring is fryed and you need to either get it re done or run a harness off the good one.
Old Sep 2, 2009 | 07:08 PM
builthatch's Avatar
MiG-21 superfan
Originally Posted by GetEfdupEH
Hey all,
-is the dull beam aimed too low?
-look inside and see if you see a difference between the reflector/shield vs. the 'good' light.
-as mentioned it also might have some lens hazing that is affecting the output.
Old Sep 3, 2009 | 05:15 AM
testdriver91's Avatar
If your headlights look foggy, you might solve the problem with a polish. You can probably get a local shop to clean and buff them for around $50? It really does help.
Don'tKnoKnuthin
Sep 13, 2013 08:35 AM
Night Kid
Jan 18, 2002 08:57 AM
HAcEx01
Jan 6, 2002 04:06 PM
