Lighting HID/Xenon kits, Retrofits and Associated Topics
Light problems, light scatters...
Old Sep 8, 2009 | 05:51 PM
FlewByU352's Avatar
Default Light problems, light scatters...
96 Civic...my headlights look pretty bright. I think my car being low makes them suck for distance? Can they be adjusted? Then my highbeams, what a joke they are. The light hardly shines further it just scatters up and out. Is there something I need to adjust? Is it just bad light bulbs?
Old Sep 9, 2009 | 09:51 AM
prelude1897's Avatar
Default Re: Light problems, light scatters...
first question is, do you have a cheap *** PnP kit or do you have a true retrofit? If you have a crappy PnP kit, then that's your problem. Have a retrofit done, and you'll see a huge difference
Old Sep 9, 2009 | 10:32 AM
FlewByU352's Avatar
As far as I know they arent HID, just replacement bulbs. If you look at them they have blue tinted glass. They dont really shine blue though its more white than anything. I saw H4/100 on them. I assume its just a halogen bulb? But why is it so crappy? I know HID's usually have the scatter problem unless you retro fit. Could it be my headlights being a tiny bit cloudy causing it to scatter?
Old Sep 9, 2009 | 11:53 AM
TunerN00b's Avatar
Blue glass = reduced lighting (it is a filter after all)
100W bulbs? And you haven't melted anything yet? I'm constantly amazed by just how over built our cars are. US laws restrict headlamps to 55W (just throwing out some info). The overpowered bulb might also be contributing to an inability to see outside of the hotspots (same reason HID kits with a halogen beam pattern hurt visibility).
Cloudy headlamp + blue bulb = scattered light. The "cooler" the color temp, the more susceptible to scatter the light is from dust and moisture in the air, as blue is a shorter wavelength.
Try resurfacing the headlamp and running a nice non-filtered bulb.
randiculus
Honda Civic (2001 - 2005)
11
Mar 22, 2007 05:30 PM
mehdiR
Jan 20, 2005 04:51 AM
ThaReal24k
Nov 11, 2004 01:49 PM
seano
81
Nov 12, 2002 06:42 PM
leesiulung
Jan 21, 2002 12:29 PM
