Lighting HID/Xenon kits, Retrofits and Associated Topics
replacing projector bulb
Old Nov 16, 2009 | 09:40 AM
92civicx's Avatar
Default replacing projector bulb
hello everbody i got these projector,halo,angel eye aftermarket headlights whatever their called. They don't look cheap they seem to be the expensive kind. it came with the car and someone wants to trade these for oem headlights. but i need to get one of them to work - both high beam and low beam lights went out.
How do i kno what kind of bulb to buy to replace the ones that are no good?
and it seems like there's some wiring done, would it be easy as just replacing them with oem headlights ?
thnx
Old Nov 16, 2009 | 10:23 AM
prelude1897's Avatar
Default Re: replacing projector bulb
sounds like you just have some cheap ebay projector headlights. If that's that case, then you just simply replace the bulbs and regular halogen bulbs. Shouldn't be hard to change out at all...Also check your fuse to be sure it's still good
Old Nov 16, 2009 | 11:22 AM
92civicx's Avatar
yeah the fuses are good. so any kind of halogen bulbs would work? can i find em in autozone or advance auto parts ?
Old Nov 16, 2009 | 11:52 AM
92civicx's Avatar
bump for help
Old Nov 16, 2009 | 07:53 PM
whatever size bulb your car normally uses is what should be used for your headlights. Happen to have any pics?
Old Nov 16, 2009 | 08:00 PM
92civicx's Avatar
i took out the bulb and it was attached to a metal part that connects to the outerplug and on the metal part it had the exact bulb size. went to autozone and replaced it. for future reference
Old Nov 16, 2009 | 08:07 PM
Teg LS's Avatar
is it the stock housings and everything? just a different bulb? then you could just buy the bulbs at autozone or checker or whatever
Old Nov 16, 2009 | 10:06 PM
92civicx's Avatar
one of those aftermarket ones, wasnt' stock "ricer" headlights some will call it....
Old Nov 17, 2009 | 09:37 AM
Teg LS's Avatar
so you just want to get new housings and bulbs for the lights? or are you trying to fix the "ricer" ones?
Old Nov 21, 2009 | 09:52 PM
98civdx's Avatar
Master Detailer
im confused, do the halos even turn on??
you will need to wire them to your parking lights, they arent plug and play.
s0biek
Honda Civic (2006 - 2015)
Jun 1, 2012 03:23 PM
jabuhanna
Jul 22, 2010 09:48 PM
inspireAZN
Mar 12, 2007 01:02 AM
EJ8 GSR-T
Nov 29, 2005 04:19 PM
boosh
Apr 15, 2004 06:06 AM
