Lighting HID/Xenon kits, Retrofits and Associated Topics
flickering light
Old Oct 6, 2009 | 11:54 AM
pornfreaktommie's Avatar
Default flickering light
my problem is my 97 honda civic ex sedan is having issue with electrical. The headlights would brighten and than dims.. usually when i accelerates it brighten up. i'm thinking its the alternator but not to sure. could it be something else? i mean my airconditioner does the same thing too, it gets stronger when i accelerates, than when i just cruise its back to normal?
Old Oct 10, 2009 | 01:45 PM
SurfDan5's Avatar
Default Re: flickering light
seems like the ballasts are not getting enough power or there not able to keep it at a consistent level.
Old Oct 11, 2009 | 10:18 AM
supasoulja's Avatar
True, if he has HID's installed in his headlights, regular holagen bulbs don't have ballasts. If he doesn't then it does sound like an alternator problem.
Old Oct 17, 2009 | 10:24 PM
cr8ter's Avatar
most likely alternator do to the fact that ur blower motor gets stronger when u accelerate...the alternator is spinning faster and putting in more of a charge therefore putting more power to the electrical supplies...use a multimeter and check the battery with car running u should put out a little over 14 volts or close to 14 volts if u are then alternator may not be the problem
97elitehonda
Jun 27, 2007 02:10 PM
Underwaterer
Apr 14, 2006 08:17 PM
AndyGCT
Feb 14, 2005 05:56 AM
Malgerus
Oct 19, 2003 10:37 AM
civcexcoupeblack
Jun 23, 2003 04:34 PM
