TrackvsStreet
Old Apr 28, 2013 | 10:01 AM
10sec4door's Avatar
Default TrackvsStreet
Ok we'll I'm kinda torn. I've had my car for about 8 years finally got it running good went 11.47 @122 on 19psi 24.4x9 slicks. This was on its 3rd pass I know with seat time I can def break a 10. This is a 2001 ITR full interior and speakers. Only problem is I only drive the car about 10 times a year. I def got the racing bug again and wanted opinions would you rather have a street car that can go low 11 high 10 or go all out racing. I will only do it if only changing a couple things in my set up can make me go 9s . It's a gsr head and block. Head fully built with port job by extrude home. Full race kit wit a 60- 1 hondata s300 bbg. Block is 81.5 wiseco eagle stock sleeves car made 493whp at 19 psi. Budget to try and go 9s is 5k
Old Apr 28, 2013 | 03:24 PM
Pipnorcali's Avatar
Default Re: TrackvsStreet
If you got a truck for towing then go race car...but I like to keep them street able so I can drive to the track
Old Apr 28, 2013 | 04:43 PM
DraginX's Avatar
I'm pretty much in the same boat at this point. Starting to think drag only is the way to go. I'm back and forth about it constantly.
Old Apr 28, 2013 | 05:01 PM
blackeg's Avatar
my opinion is that if you only drive it 10x a year, go for the race setup.
while i dont drive my 11 sec street car much in the winter if there is a ton of salt on the road, i definitely drive it on nights and weekends when the weather warms up. its a good compromise
Old Apr 28, 2013 | 06:49 PM
10sec4door's Avatar
Yea the ? Now is will 5k upgrading turbo clutch and sleeves get me where I wanna be ?
Old Apr 29, 2013 | 04:20 PM
d16z6Tcrx's Avatar
its do-able. my car was a full interior non-cut street car with heat and wipers. my build thread is on here somewhere. drove the car every chance i could. made 693whp on stock sleeves and ebay clutch. best time in it was 10.5 on 20psi. was on it way to 9's but i sold the setup completely and it just went 10.2 in an eg at honda day.
trick is to keep it simple. on the street i only ran the wastegate. if you dont want to run a twin disc try the new super singles out. the seem to be working pretty well.
Old Apr 30, 2013 | 02:02 AM
Natural Aspirations's Avatar
5k isn't going to get you from a 11.5 to a 9.9. Price goes up exponentially as soon as you hit the 10.9 range. That extra second will likely cost twice your budget.
Old Apr 30, 2013 | 04:06 AM
Tuner Eddy's Avatar
My car is running around the same times you are and I drive it less than you do. But keeping it off the street helps avoid any tickets or wrecks on the street.
A 450-500hp setup is also good to start out with, but you'll want to go faster after a few times out, as you're seeing.
Every car is different, nonvtecallmotor went 9's with ~650hp (if im remembering a post of his a few weeks back), every car and driver is just different.
Old Apr 30, 2013 | 05:38 AM
DraginX's Avatar
And track makes a difference to. Locally we only see compound for maybe the first 330'. Unlike places like MIR who have compound the entire 1320'
Old Apr 30, 2013 | 06:11 AM
SP GARAGE's Avatar
You can go 10's on stock sleeves if the car is setup properly.. Such as chopping up the car, suspension.. Buddy of mine made 540 on stock sleeves and went 10.40's hitting the limiter before the line
Old Apr 30, 2013 | 06:39 AM
Snailor Built's Avatar
What are the super singles? Ill get off here and check more , interested in hearing a bit more about them.
Old Apr 30, 2013 | 07:09 AM
turbo-2nr's Avatar
For me the car made a little over 500whp was out of pump, injectors,Turbo,needed sleeves
So the next step was to turn it in to a track car and to do that was another $10k
I made the decision to leave the Honda I loved so long and buy a S14 240sx and put a 2j in it for around the same cost and have a car that will be much faster and more streetable, it's not the way to go for every one but I just couldn't see myself owning a car that I couldn't drive daily if I wanted to
Old Apr 30, 2013 | 07:40 AM
13173's Avatar
Leave it a street car. For one, you say that you have a full interior 2001 ITR. A limited production car. I would not cut it up or do anything to it personally, as those cars are obviously more rare and would probably be worth more if it were closer to all original.
A $5k budget is a tight budget to work within if you are planning on making it more of a race car. Cage, turbo, turbo mani, etc. That stuff adds up super quick.
Personally, I would leave it the way it is and have fun with it. People often forget that a mid to low 11 sec street car is still a fast car!!! And to bring it up again, it's an ITR, I am partial to those cars and could not see myself cutting it up any at all to make it a race car unless it was a theft recovery or something along those lines.
Old Apr 30, 2013 | 02:55 PM
NoWorry's's Avatar
^^X2 was wondering why somebody hasn't brought this up..
Also you should look into these CSS blocks.. there was a thread up on them the other day for budget drag racers..
https://honda-tech.com/forums/drag-racing-36/css-block-users-unite-3141064/
Old May 1, 2013 | 10:36 AM
10sec4door's Avatar
Yea the car is beautiful only thing not worth as much. Gsr stamped motor salvage history. Don't get me wrong I put 25 k into the car it's beautiful but not worth as much as an original non molested R and I would save all parts to return To stock if I had to
TeknikDC2
Jul 11, 2009 06:35 PM
Full-Race Geoff
Oct 18, 2008 01:19 PM
uglyasscivic
Jul 10, 2008 05:46 AM
Topdawgg
Oct 7, 2006 06:53 AM
