lets talk valves.
Old Jun 19, 2013 | 06:18 AM
MR.johnson's Avatar
Default lets talk valves.
so, over the weekend i destroyed my dart block and everything bolted to it. the stem didnt lock in the guide, it seems the head broke off the stem.
what valve is everyone having good luck with, been running hard for a while...
Old Jun 19, 2013 | 06:38 AM
sohc95vtec-t's Avatar
Default Re: lets talk valves.
Ferrea 6000 here
Old Jun 19, 2013 | 06:39 AM
Zer0_SpeedWorks's Avatar
Ferrea comp plus. Plus ferrea valvelock. Oem guide though.
Old Jun 19, 2013 | 06:53 AM
SPOOLINmatt's Avatar
I had an ST valve break off at the head of the stem back in 2011. oyyyyyy
I use all ferrea 6000 at minimum now.
Old Jun 19, 2013 | 08:08 AM
luck4rmkc's Avatar
Ouch man really sorry to hear that. Your car was such a beast for a 62mm setup.
What valves were you running?
Old Jun 19, 2013 | 08:58 AM
90blackcrx's Avatar
Seen of a few supertech valves do the same ( but some also weren't 100% the valves fault ) ... we use Ferrea now a days though on larger setups.
Old Jun 19, 2013 | 09:52 AM
nonvtecallmotor's Avatar
I will only use ferrea comp plus in my car. Save your money now or spend big $$$ later..
Old Jun 19, 2013 | 10:22 AM
extralargenog's Avatar
Ferrea
Old Jun 19, 2013 | 10:58 AM
snobordboy's Avatar
Moderator
Chalk up one more for Ferrea!
Old Jun 19, 2013 | 11:01 AM
01DC4's Avatar
Supertech.
Old Jun 19, 2013 | 11:08 AM
AZ_CIVIC's Avatar
Ferrea Comp Plus is what I use.
Old Jun 19, 2013 | 11:35 AM
E Town DSM's Avatar
Ferrea comp plus only. Install is a huge key with any valve.
Old Jun 19, 2013 | 03:55 PM
got-vtec?'s Avatar
Will be using 6000 series in my head, though I was suggested to use comp plus. Whats the determining factor(s) to use the comp plus? Hp, rpm range, etc?
Old Jun 19, 2013 | 04:21 PM
Boosted_01 R's Avatar
that really suck, what valve were you using ?
Old Jun 19, 2013 | 05:13 PM
jdm inc's Avatar
will be running supertech this time around.
Old Jun 20, 2013 | 04:11 AM
EJ1_Ex's Avatar
Damn brotha, sorry to hear.
Old Jun 20, 2013 | 04:13 AM
MR.johnson's Avatar
thank you everyone! ferrea comp should be fine for a street car right? I will release the name of the company after I hear back from them about my situation.
so get the matching springs and retainers too I take?
Old Jun 20, 2013 | 04:26 AM
josh green's Avatar
I've never had a bad experience with ferrea valves and probably wouldn't consider anything else.
Old Jun 20, 2013 | 06:20 AM
AZ_CIVIC's Avatar
For sure, get the entire Ferrea valve train with the exception of the Valve Guides. Jason at CNC Port told me when they did my head they never use their valve guides because they are too big and have cracked.
Old Jun 20, 2013 | 06:22 AM
snobordboy's Avatar
Moderator
The comp plus are made for high heat situations i.e. Forced induction or nitrous use.
A few head guys that I talked to suggested to run 6000 series on intake, and pro comp on exhaust side, to save a little coin.
Old Jun 20, 2013 | 06:37 AM
Topdawgg's Avatar
Ive had supertech in my car for 6 years with no issues..
Bought their new springs and the inconel valves last time I had the head off for a refresh..
Old Jun 20, 2013 | 07:07 AM
mint's Avatar
Supertech has worked great for the last few years!
Old Jun 20, 2013 | 08:52 AM
My guess is STs failed you... AMIRITE
Old Jun 20, 2013 | 09:30 AM
MR.johnson's Avatar
nope lol.
Old Jun 20, 2013 | 12:08 PM
MR.johnson's Avatar
anyone have this problem?
