e85 id2000 tip in issue.
Old Jul 1, 2013 | 11:13 AM
popwars123's Avatar
Default e85 id2000 tip in issue.
Hey all, for a little background I have a 6262 b series that makes 651whp. Tune is great and all but I have been having bog between gears that I cannot figure out all the way.
It's on e85 with ID2000. Neptune with Moates Demon
My throttle tip in setting is -80.
Tps is reading right.
Between gears when you stab the throttle again it hiccups a good amount, so this results in bad response between gears and essentially slow track times. ( I know I can Wide open throttle shift if I want to, but I want to actually resolve the issue).
I have tried messing with the setting some and can't seem to get it all the way right.
I was wondering if you guys may have some insight and also what you have ended up with tip in settings and maybe vaccuum map fuel/ignition values for ID2000 on e85.
Thanks in advance!
Old Jul 1, 2013 | 12:49 PM
Turbo-LS's Avatar
Default Re: e85 id2000 tip in issue.
are you pulling a lot of timing on the tip in ?
Old Jul 1, 2013 | 01:14 PM
dester223's Avatar
I am assuming you are using hondata s300 for the tip in %? Can you send me your file and a log of when it happens (multiple logs will help)
I typically just look at the injector duration and what it's doing between the gear change. That helps setting that % easier.
Old Jul 1, 2013 | 01:16 PM
OneSixxKyle's Avatar
I had the same Problem in my hatch; I called injector dynamics and they took my injectors back and tested them. they told me the bog in between gears is because i was using to small of a micron fuel filter therefore the e85 was having build up and clogging my injectors what fuel filtration system are you running?
Old Jul 1, 2013 | 02:54 PM
popwars123's Avatar
Thanks for the replies, this has been quite a headache:
Turbo-Ls: The timing is around 48 degrees in low vacuum maps. Base retard on tip in is set to 21.25.
dester223: I can email a datalog but It seems to happen too fast for the datalog to catch it. I am running Neptune.
OneSixxKyle: I am running a 100 micron pre-pump and a 10 micron post pump.
If anyone would like to analyze my file I can email it as well.
Old Jul 1, 2013 | 04:30 PM
xbigpitax's Avatar
check your injector clips i had a similar problem and it was that
Old Jul 2, 2013 | 06:11 AM
00ITR #543's Avatar
-Filters should be SS mesh... Magnaflow makes a mesh pre and post filter. If you have the Aeromotive ones, they are not SS mesh.. Aeromotive 10 and 100 are fabric filters. Aeromotive makes a 40 micron mesh element you can replace with.
- Make sure your dead times are correct. The rich condition tip-in is more related to your fuel tables in low vacuum being too rich. Injectors are big but are very responsive... Correct deadtimes and correct vacuum afr is important. A lot of times you will not have to adjust the throttle tip-in/ tps accel rates from your base.
Old Jul 3, 2013 | 03:19 PM
Gunmetal_B20_Hatch's Avatar
wideband in car? is it rich or lean during when the problem occurs?
Old Jul 5, 2013 | 11:20 AM
Lazysk8r2's Avatar
i have mine set to +30%. why are u pulling out 80%?
Old Jul 5, 2013 | 11:52 AM
Bugermass's Avatar
set to like -40, -80 is way too much..
Old Jul 5, 2013 | 12:04 PM
SpokaneSpeed's Avatar
80%?? Where/Why did you get that figure to use??
Old Jul 5, 2013 | 12:59 PM
popwars123's Avatar
-90 is what the adjustment is for id2000's in Neptune, and on e85 the Calculated difference would be -60. I had set it to -60 and it seemed to be too rich though.
Old Jul 5, 2013 | 01:02 PM
popwars123's Avatar
I will try lower values. The car is down right now but the transmission will be going back in in the next few days so I will try. I also am going to try adjusting the vtec low load threshold as my tuner thinks that could be at fault. May take out some low vacuum fuel as well if the -40 doesn't work.
Thanks for the input!
Old Jul 5, 2013 | 01:16 PM
Turbo-LS's Avatar
You should be running an e85 fuel lab filter its 5 micron and e85 compatible 10 is said to be to large
Engine Management and Tuning
83
Dec 5, 2019 05:05 AM
bluenc-87
Aug 22, 2015 01:53 AM
thewrai6th
Jun 29, 2007 01:41 PM
rice a roni
Jan 28, 2007 05:53 AM
GruvyTune
Nov 1, 2001 02:02 PM
