Question about c16?
Old May 25, 2013 | 08:10 AM
turbo boost's Avatar
Default Question about c16?
i just had my car on the dyno and this is the first year ive used vp c16..in past years ive used pump and meth....this year im having breakup issues in the upper rpm....the car has stock ignition...now my question is ...is c16 harder to ignite with the stock ignition?...would this be causing the missfires?...its at 597whp, setup is
2.0L lsvtec
6766 t4 1.15
topmount
pro1s
victor x
s300
bkr8eix .019 gap
stock ignition
the reason i ask is last year it made 612whp with the pump and meth with no miss fires?
any input would be great
Old May 25, 2013 | 08:15 AM
CDecker0218's Avatar
Default Re: Question about c16?
I had stock ignition while using c16 and never had that problem. After I bought the M&W Pro 10 iginiton it didn't change anything so you should be fine. I would ask your tuner though to be sure.
Old May 25, 2013 | 02:19 PM
CDizzle_996's Avatar
Try gaping your plugs lower
Old May 25, 2013 | 03:58 PM
itspools's Avatar
What's your Afr before break up occurs?
Old May 25, 2013 | 05:40 PM
got-vtec?'s Avatar
you're ignition might just be on its way out, that's a good amount of power for stock ignition. if you plan on upgrading check out the Summit streetnstrip digital box. Basically Mallory internals. Along with a coil from MSD, Crane, etc. Ive yet to use mine but theres a number of people on here with the same set up and wouldn't complain.
http://www.summitracing.com/parts/crn-730-0892
http://www.summitracing.com/parts/sum-850610
Not a bad upgrade shipped to you for under $250
Old May 26, 2013 | 06:11 AM
KARBOYZ's Avatar
Lower gap to .012 - .014
Also you could try 7 plugs. I had misfire with 8s and switch to 7s and it went away.
Old May 26, 2013 | 07:42 AM
FRernesto's Avatar
Make sure timing was set correctly.
Old May 26, 2013 | 10:01 AM
a/f's were in the 11's....would .019 be to much gap?...i tryed 7's and it was still there....next ill try is gapping them down to .012-.014
Old May 26, 2013 | 02:55 PM
It could be blowing out spark up top. Gradually go a bit tighter until it stops, if that's the problem...
Old May 26, 2013 | 03:03 PM
ok ill try that...also would a m&w pro 10 fix the issue? would it let me run a bigger gap with no missfires?
Old May 26, 2013 | 05:47 PM
DA 4 Lyfe's Avatar
Yes. I have the M&W Pro 10 with BKR7E plugs. They are at .28 running C16. No ign. issues
Old May 26, 2013 | 07:50 PM
KARBOYZ's Avatar
Yes the M&W would. But I think you should fix the issue you are having first before getting the M&W. Gap those plugs and see.
Old May 26, 2013 | 08:10 PM
jdm inc's Avatar
i was previously running a digital 6 had ignition break up it ended up being my igniter was going out. so I switched to the pro 10 and never had a problem.
Old May 27, 2013 | 08:29 AM
SPOOLINmatt's Avatar
what is your ignition timing set at in the table at the point of the breakup. rpm/boost
Old May 28, 2013 | 09:03 PM
AFAccord's Avatar
I'm running close to this on 7's with stock ignition with absolutely no problems, but I've always been curious if there are any drawbacks to having such a small gap?
Old May 28, 2013 | 09:19 PM
CO_RaceFab's Avatar
.013
HybridEL
Jan 26, 2008 02:38 PM
yaaj1320
Mar 10, 2007 11:35 PM
SiRkid
Dec 15, 2006 10:53 AM
g2turbo
Feb 10, 2003 01:04 PM
Cashflo
Aug 11, 2002 12:35 AM
