800HP Setup ?
Old May 28, 2013 | 08:30 AM
Steeve_Civic's Avatar
Default 800HP Setup ?
I'm running at the moment AEBS Sleeves,Eagle Rods, CP pistons, standard Supertech valves.
Do I need to switch with Manley rods and Ferrea Valves please?
I heard about the limit of 700HP for eagle rods and Standard Supertech valves?
Do I need to be careful about something else?
My Turbo is a 6766 T4.
Thks
Old May 28, 2013 | 09:55 AM
tkHBseries's Avatar
Default Re: 800HP Setup ?
I'm on eagle rods with upgraded wrist pins and rod bolts pushing 800+whp...all depends on the tune and assymbly. Good luck on your build.
Old May 29, 2013 | 05:56 PM
The Show Stopper's Avatar
Eagle rods are a bomb waiting to twist. nothing good ever comes out of a set of $300 rods
Manley and Eagle both use ARP2000 rod bolts so there is some food for thought
Carillo w/CARR bolt or Manley Turbo Tuff w/625+ bolt would be my recommendation unless you like to play with fire
Rob-
Old May 29, 2013 | 07:01 PM
ls_on_boost's Avatar
Rob-
x2
Old May 29, 2013 | 07:07 PM
boostontheD's Avatar
Rob-
X3
Rob was nice enough to fill me in on what I should get for my build that's about the same power levels. That's why he's also doing all the maching work and assembly. He knows his ****.
Hoosier Daddy
Oct 28, 2003 07:18 AM
ARACER25
Oct 19, 2003 09:22 AM
liam821
Aug 13, 2003 04:32 PM
Kevin
Aug 11, 2003 10:53 AM
