braking setup.
Old Jun 5, 2013 | 06:38 AM
MR.johnson's Avatar
Default braking setup.
going to be getting a real stagging brake and a boosterless front system. what size wilwood master is everyone using? i understand the larger the bore the stiffer the brake will be. is the 3/4 too small to run the front brakes?
Old Jun 5, 2013 | 03:18 PM
hondaracing84's Avatar
Default Re: braking setup.
I use the 7/8" willwood
Old Jun 5, 2013 | 07:22 PM
jdm inc's Avatar
ill be using the tilton 7/10
i know some people use the wilwood 5/8 one also
Old Jun 6, 2013 | 04:35 AM
MR.johnson's Avatar
stiff? car stops good over 150?
do they like the 5/8 one?
Old Jun 6, 2013 | 10:37 AM
I guess you could say its a little stiff. But I believe its that way because of no booster. Just makes it a little more difficult to push with out the assist of a booster.
I stopped just fine from 146mph to 150. Ive only been 150.65, so over that, I dont know. Id probably use a chute past that point though. I actually did use it on the 150.65 speed.
austenjanzen
Suspension & Brakes
Jun 1, 2016 09:42 PM
lopezchris21
Sep 27, 2014 11:20 PM
traxxasx
Feb 28, 2008 01:19 PM
rotten
Jul 15, 2006 11:40 PM
Wideopentuning
Welding / Fabrication
Jul 4, 2005 12:24 AM
