Honda CR-V & Element 2WD & 4WD Element & CR-V
Water pump?
Old Feb 7, 2018 | 06:03 AM
Tunedwhitey's Avatar
Default Water pump?
So i replaced head gasket, timing chain and tensioner and got the head resurfaced recently. So I went to go bleed the coolant system and when it warmed up I started hearing a popping noise from the top radiator hose. Thermostat didn't get to open. Could it be that it's a bad water pump?
Thanks in advance
Old Jun 26, 2018 | 11:59 PM
EthanN15's Avatar
Default Re: Water pump?
Thanks in advance
No, most likely air in the system and water is not reaching the thermostat. Had the same problem after replacing my head gasket. Make sure to bleed the system preferably with a filler bucket that attaches to the top of the radiator where the cap goes and let it fill with the car on with heater on for at least 20 min. Should get rid of any air.
DK-EK9
Feb 14, 2012 09:20 PM
acuralovar
Feb 14, 2010 12:11 AM
young geezer
Dec 8, 2008 05:21 PM
turbohb21
Aug 7, 2007 08:43 PM
regdog77
Apr 12, 2007 04:44 PM
