Honda CR-V & Element 2WD & 4WD Element & CR-V
2004 CRV starter, issues
Old Jul 22, 2024 | 12:10 PM
coltfan's Avatar
Default 2004 CRV starter, issues
After car sits, can turn key and no noise, clicking, etc.
Turn off and back on it will start ,sometimes on and off 2 or 3 times success.
Thanks
Bruce
Old Jul 23, 2024 | 12:49 AM
easy129's Avatar
Default Re: 2004 CRV starter, issues
Probably the starter. I had same issue with my 04 Element. Get the battery checked out as well.
Old Jul 23, 2024 | 03:17 AM
coltfan's Avatar
Thanks,not sure if this can cause,but did get error codes checked out.Knock sensor ,I had a backfire and believe I fixed it with finding a loose vacuum hose on breather near air filter.So Wonder if a bad sensor would cause a very intermittent issue like this.But definitely think it is a starter issue
Old Jul 23, 2024 | 05:14 PM
Ryanthegreat1's Avatar
Knock sensor error has no influence on the starter. They are right next to each other. Might be wise to replace the knock sensor while you are in there replacing the starter.
Old Jul 23, 2024 | 05:32 PM
coltfan's Avatar
Thanks Ryan
I'm unable to do much repair work anymore.definitely appreciate that tip,as that was helpful!
Another stupid question ,is hate to take car to shop ,I'm in a small town and tell them to replace starter,is their a precise way for a good mechanic, assuming I find one available to confirm a bad intermittent starter ,I have no clue?
Thanks y'all 4 the advice
prelude2001h22a
Nov 22, 2014 02:04 PM
old-sk0ol
May 12, 2010 12:41 AM
BK101
Oct 12, 2004 09:38 AM
