Honda CR-V & Element 2WD & 4WD Element & CR-V
Engine swap compatibility
Old Mar 17, 2024 | 05:29 AM
Reddcarr's Avatar
Default Engine swap compatibility
I am absolutely certain this has been flogged to death but I can't find it. I have a mint k24A8 that I'd like to install in an 02 crv with the k24A1 that's using oil. I have no issue changing sensors, etc, whatever is nesessary within reason. Around here a JDM A1 runs around 1800 bucks so if I can repurpose this one it'd be great. Thanks in advance
Old Mar 17, 2024 | 06:43 AM
Ryanthegreat1's Avatar
Default Re: Engine swap compatibility
Probably going to be an intake manifold swap and the rest should work.
Not 100% sure on the coolant block situation on the transmission end of the head. Those were frequently updated and changed.
Old Mar 17, 2024 | 10:28 AM
Reddcarr's Avatar
My main concern is that the cams are the same. Everything else is, with exception of the intake and possibly the thermocase.
Old Mar 17, 2024 | 04:10 PM
Why do the cams need to be the same?
Old Mar 17, 2024 | 04:38 PM
Reddcarr's Avatar
Don't know if it matters. The '02 ecu might not be compatible with the A8? That's why I'm asking. I can't be the only one who's wanted to do this swap
Old Mar 17, 2024 | 06:48 PM
Close enough to probably not matter. They are both ~160hp. Fuel system is capable of adjusting +/-20% without complaining.
blkonblkhatch
Mar 8, 2006 07:15 AM
FuNkDrSpOt
Aug 1, 2005 10:18 AM
FlyWithMe825
Sep 28, 2004 10:58 AM
